Morimoto Xb LED Angel Eye Kit Install (2011 WRX) - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
This is a discussion on Morimoto Xb LED Angel Eye Kit Install (2011 WRX) within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I believe its called a Vampire tap Sent from my SCH-I545 using Tapatalk...
  1. #31
    Jan 2012
    New Jersey
    I believe its called a Vampire tap Click image for larger version.
    CFLip2x 2012 WRB WRX Build
  3. #32
    May 2014
    @cflip2x, Thanks for the picture. It helps a lot.
  4. #33
    Jan 2012
    New Jersey
    You may want to add some dielectric grease around the connections before wrapping them with electrical tape to help prevent corrosion
  5. #34
    May 2014
    Know what relay harness to use to tap to the DRL power line? Know any good online store?
  6. #35
    Jan 2012
    New Jersey
    Ebay you can find some 30/40amp relays and harnes combos even if they are the 5 pin just don't use the middle pin. Get some 16gauge wire,an inline fuse, and some ring terminal ends
  7. #36
    Sep 2005
    Quote Originally Posted by cflip2x View Post
    Fyi, these are some of the worst and most unreliable electrical parts... I would not use them anywhere in a car.
    You're better off cutting the wires and making a Y-splitter out of some spade terminals...
  8. #37
    Nov 2012
    Tulsa, OK
    Great write up man, I'm probably going to try this myself sometime!
    - David
    Tulsa, OK
    - '69 Chevy C-10 (HS project with dad - still have it)
    - '14 2.5L WRX Hatchback WRB aka "Sonic"
    "If you can do something about it, then why worry; if you can't do anything about it, then why worry?" - Buddhist Philosophy
