Does baking headlights for disassembly cause any longterm adverse effects? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Does baking headlights for disassembly cause any longterm adverse effects? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Take Luck When I installed my halo I made a couple of holes close together on the bottom just under ...
    Jan 2012
    New Jersey
    Take Luck
    When I installed my halo I made a couple of holes close together on the bottom just under the shroud to feed the wires though. I also removed the black connector so they would feed though easier you can easily just cut off the tips but I wanted them still on just in case.
    CFLip2x 2012 WRB WRX Build
    Registered User Miggs's Avatar
    Jul 2013
    North Carolina
    All done! turned out great. pics to follow. i wiring mine into my parking lights. must. eat. food.
    Moderator smorris's Avatar
    Mar 2002
    Avon, Ohio
    I did mine almost 12 years ago. They've never fogged or leaked, and the car lives outside year 'round.
    Steve - Avon, Ohio, USA - Moderator - Fun Drives and North Central States
    Explore the USA
    2016 Toyota 4Runner__2008 Outback 2.5XT Ltd (sold) __2002 WRX Wagon (sold) __ 1958 MGA Roadster __ and a few scooters...
  5. #19
    Jul 2013
    North Carolina
    Posting pics and thoughts to build thread
    Chronicles of a 2011 WRX
  6. #20
    Registered User Stovetop26's Avatar
    Nov 2013
    Maryland
    Came out pretty nice man. Can't wait for all of this crappy weather to clear up so i can do mine.
  7. #21
    Registered User BryGuy's Avatar
    Jan 2014
    I did mine anout a year ago. I noticed that i did get clouding after though. Its not moisture and I polished the inside and outside of the lenses so i know it isn't scratched. I have a feeling its chemicals from the paint and silicone after reheating it to squeeze them back together.
    You can see what i mean here. This is right after installation:
    And a few months later. Notice just above the halos:
  8. #22
    Nov 2013
    Maryland
    interesting, do you remember what kind of paint you used?
  9. #23
    Jul 2013
    North Carolina
    Quote Originally Posted by BryGuy View Post
    It would seem that that is a pretty common problem on the outside of the lens on Subarus. I sand mine several times a year, even before I did the halo mod. I haven't noticed any extra contamination to the assemblies since doing this mod (knock on wood)
  10. #24
    Jul 2013
    North Carolina
  11. #25
    Jul 2013
    North Carolina
    Quote Originally Posted by Stovetop26 View Post
    I didn't paint mine, as 2011's came black. This is what Mammal did to his,
    Quote Originally Posted by Mammal View Post
    I had my body guy spray them in his booth. I don't recommend using cheap walmart or autozone paint since over time it will crack and fade due to uv light. Anyway, my body guy prepped them with an epoxy primer and used an automotive grade ppg paint. The housing paint job will pretty much last forever now lol.
    His build thread:
    Mammal's SWP 13 WRX (third times a charm)
  12. #26
    Jan 2014
    I can't say for sure, but since it was a small plastic piece i probably used something cheap since it would be hard to mess up.
