Front Bumper re-install, clips under headlight not seating right
Results 1 to 15 of 19
This is a discussion on Front Bumper re-install, clips under headlight not seating right within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; So I put my hella horns in this weekend. All went well, but the bumper is not snapping back in ...
    Registered User AFP520's Avatar
    Aug 2005
    NJ
    So I put my hella horns in this weekend. All went well, but the bumper is not snapping back in properly under the headlight (where the turn is signal bulb is.)
    I know many of you guys have pulled your bumpers off by now, what's the trick to getting this right? And where can we buy more of the plastic snaps that hold everything in? I lost one in the fender well.
    '14 SWP STI
    Registered User SDub's Avatar
    Feb 2013
    They have assorted snaps at home depot/Lowes in the screw/fitting aisle. I always go there for various snaps, plugs, buttons. Exactly like OE ones.
    But I put the horns on my buddies '13 and all we had to do was remove the grill, there was no need to take off the bumper. Unless of course you place the horns someplace else like behind the bumper.
    Just from my experience tho.
    Sent from my Fone
    Aug 2005
    NJ
    I did some reading on it and it seems like a common problem. Once you pull the bumper off, the clips are so close to the fender they don't allow enough room to make the bumper slide over the clip under the headlight. Look at this pic and you can see it. http://i48.tinypic.com/24lvbdg.jpg
    '14 SWP STI
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by SDub View Post
    I haven't been able to find the clips at Home Depot, but yes, Lowe's has an automotive hardware sections that carries all sizes of plastic rivets. NAPA/most other small automotive shops also carry them. I always get mine at NAPA.
    2007 Outback 3.0R wagon
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    You can always get the clips at the dealers parts dept. I have even seen them on Amazon. Its not easy to get the bumper back in place once you take it off. It never fits as it was from factory. I just pushed it back into place under the headlight. Just don't give it too much force or you can break something.
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Registered User BLAZE2099's Avatar
    Jan 2011
    bloomsburg pa, usa
    Mine was trying to be pitd, so I called it names and forced it back on.
    Randy-
    2011 WRX limited
    02 blaze Wrx-sold
    04 Wrx pos- sold
    99 forester
    People say I'm like the girl next door,
    Y'all must have some really weird neighbors-Kelly Clarkson
    Oct 2012
    I backed out of a steep narrow driveway yesterday and the drivers side front bumper slammed into the ground, broke off the wheel well fasteners and now I can't get the damn thing flush near the headlight. WTH, I can get the fasteners no problem but what's this about the bumper not fitting right ever again?
    Not so much anymore.
    Jan 2011
    bloomsburg pa, usa
    Depends on how you stretched it off.
    Exaggerated a bit above, just cursed a little.
    My comes off and goes back on with just a bit of force. You may have jacked up your sliders.
    Randy-
    2011 WRX limited
    02 blaze Wrx-sold
    04 Wrx pos- sold
    99 forester
    Jan 2012
    New Jersey
    I had the same problem with mine but just lived with it. I was maybe thinking going the bumper faster route though may look ricy
    or
    CFLip2x 2012 WRB WRX Build
    Jan 2011
    bloomsburg pa, usa
    I feel that some rice is, to ones opinion.
    I personally wouldn't do it. But I personally don't make your car payment
    Randy-
    2011 WRX limited
    02 blaze Wrx-sold
    04 Wrx pos- sold
    99 forester
    Oct 2012
    You can see where it won't snap on at the top to become flush, and as you back away I don't think you can really notice it. I can see the clip, but I can't push it up far enough to snap on. I'll break something if I apply any more force. Looks like if I remove the battery, I might be able to get some leverage from inside. Don't know if it's worth it.
    Jan 2011
    bloomsburg pa, usa
    Is the tab or catch maybe broken? Odd that that's the only spot it won't click.
    Randy-
    2011 WRX limited
    02 blaze Wrx-sold
    04 Wrx pos- sold
    99 forester
    Oct 2012
    The tab and the catch are both intact. I just can't clear the metal border, I'd have to push on it from the inside or something.
    Jan 2012
    New Jersey
    mine looks similar. my plastic tabs are a little "warped" from removal but its holding and I just deal with it
    Oct 2012
    Mine doesn't stay very flush anymore and I'm wondering if I should pay someone to do it. That upper tab right at the headlight if crucial to keeping the part secured.
    Maybe the dealer has a trick to getting this back on or should I just go to a body shop? If I go over any bump, I have to reattach the other tabs or it's quick obvious it barely hanging on....
