roof rack
Results 1 to 6 of 6
This is a discussion on roof rack within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; hi guys, im new to the forum. i just bought a 2008 wrx wagon and it has the factory roof ...
    Oct 2013
    roof rack
    hi guys, im new to the forum. i just bought a 2008 wrx wagon and it has the factory roof rack on it. i havent really looked into it, but am not sure on how to remove it. i saw someone on another site say they had to remove the whole headliner inside and unbolt from the inside. i would like some clarity on this issue.
    also.. do any of you have roof racks on your cars? i actually like the look of the rack but would like to get a wind fairing for it, as well as a snowboard attachment. if you have any input on styles/brands let me know, as well as what would attach to the factor crossbars. thanks
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    The roof rack is screwed down from the outside. There is a plastic cover in the side of the black plastic footing, a torx head screw under there goes into a rail in the roof surface. Once removed there is a plastic cover hanging there - it fits in the slit and covers the screw hole. If no one else steps up before later in the evening I'll get a few pics...
    Oct 2013
    thanks Ingo, that is what i assumed, until i read that other comment. and i have opened the plastic cover, but have never seen that type of screw. its no normal torx ive seen.
    Jul 2013
    It should be a T30-size star bit. Not exactly the most common size, but my nearest Lowe's had had a 2-pack of T30 star bits for like $3, so you should be able to find one somewhere.
    Oct 2013
    this is what it looks like. definitely not a torx. sorry i could have posted a picture earlier.
    Mar 2012
    Position 1 shows screw and tool. This is just a cover that needs to be removed to get to 2: wing-screw that holds the "footing" onto the roof rail. I pulled that screw out to show its length. The screw you show seems to be a retrofit, probably to keep from getting it stolen. Sorry, can't help with that shape, the original is torx, and 30 may be right. The rack comes with a torx tool, looks like a crew driver with that type of business end.
    Sorry, the pics I'm trying to show won't upload. I have space but the upload just hangs. Maybe later. Try to make sense of what I wrote above anyways....
