Need wheel advice.
Results 1 to 15 of 15
This is a discussion on Need wheel advice. within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I purchased inexpensive aluminum rims for my winter setup, bit they are too bright against my black car. What do ...
    Registered User twister8008's Avatar
    Aug 2011
    ND
    Need wheel advice.
    I purchased inexpensive aluminum rims for my winter setup, bit they are too bright against my black car. What do you suggest? Should I just sand, prime, and rattle can them, or would plasti dip be the way to go?
    Yellow lights mean go faster!!!
    Registered User tesla317's Avatar
    Aug 2012
    Plasti-dip them first, if you really like the look then u can do a more permanent paint job/powder coat. That's the beauty of plasti-dip!
    Registered User dloring's Avatar
    Jan 2012
    long island, ny
    just plastidipped my winter setup last week (better to do it now, when it is warm outside, plastidip goes on much better in the higher temps).
    Palmyra, NJ
    Plastidip is probably gonna be fine for now. That way if it gets messed up, you can peel it off and do it again.
    Aug 2011
    ND
    Yeah, my thoughts also. I ordered four cans of matte black.
    Jul 2012
    Rocky Top
    I like aluminum on black, hence my wheels. Hyper Silver Enkei and black car. Post pics when you get them on!!
    Aug 2011
    ND
    Need wheel advice.
    This is what they look like. I will be plasti dipping them.
    The Member michaelwfox's Avatar
    Nov 2011
    North GA
    I agree, those are too bright. Plastidip will look great in my opinion!
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Hawk-Eye Alliance #1856...ssshhh don't tell anyone!
    Palmyra, NJ
    those will look good in black for a winter set
    Aug 2011
    ND
    How do the lug nuts work when you plasti dip? Obviously the dip will come off when you tighten the rims. Do you just paint them after try are tight in the car? I am painting the rims off he car.
    Nov 2011
    North GA
    Yeah you can spray the lugs with plastidip after everything is installed. Just be sure to protect the brakes from overspray.
    That or get some anodized lugs.
    My "Build" Thread!
    2015 VW GTI
    2006 WRX TR - SOLD
    Aug 2011
    ND
    Thanks! I am going to go with these:
    http://www.amazon.com/gp/aw/d/B00BAZ...sr=8-1&pi=SL75
    Aug 2011
    ND
    Need wheel advice.
    Going with black instead.
    Palmyra, NJ
    Quote Originally Posted by twister8008 View Post
    I honestly wouldn't cheap out on lugs. Get something known like Muteki or Gorilla or something at least...I also wouldn't get aluminum lugs either. Last thing you want is a lug sheering, warping, pitting, etc. or worse, causing you to sheer off a stud. Aluminum is soft and can corrode much easier than a Chromoly steel type alloy. You're not a racecar that is constantly removing/replacing lugs. You see poor weather. Get something you know will stand up to the beating
    Aug 2011
    ND
    Ok man. I really appreciate the advice. I though a lug was a lug. I guess that makes sense. In that case, can you help me find a set tht would match both a black plasti dipped rim and the factory 2012 STI rims? I figured if I was going to buy really nice lugs I should use them both seasons. . I am color blind so I would appreciate your color advice!
