H.I.D. DRL flicker
Results 1 to 5 of 5
This is a discussion on H.I.D. DRL flicker within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Had a pair of H.I.D. Lights installed professionally on my 03 WRX and the low beams work fine only when ...
    Registered User Bumblebee92's Avatar
    Dec 2012
    PA
    H.I.D. DRL flicker
    Had a pair of H.I.D. Lights installed professionally on my 03 WRX and the low beams work fine only when I turn my lights on. My DRL on the passenger side will flicker or sometime not come on at all. If I switch from low to high beams it happens occasionally too. I have already replaced a 35 watt ballast once and it hasn't changed. On my garage bill it says the factory wiring was reversed polarity. It's that's true doesn't that mean that my lights would not have worked at all??? Need as much help as I can get. Inspection is up at the end of this month :/
    Palmyra, NJ
    Did you have a projector retrofit done?
    Dec 2012
    PA
    I'm not exactly sure but all I know is I bought the lights, bulbs, ballasts, warning canceled a and everything preassembled from the manufacturer.
    Registered User ElusiveSAV's Avatar
    Jun 2013
    PA
    you need to buy a canceller. if I spelled that correctly. that should stop all flickering problems.
    Dec 2012
    PA
    So your saying that one of the cancelers could have gone bad??
