Results 1 to 5 of 5
This is a discussion on Wheel spacer opinions within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Ok ok before you guys/gals start asking me if I did my own research, the answer is Yes! I have ...
    Registered User Pozito's Avatar
    Mar 2013
    Ok ok before you guys/gals start asking me if I did my own research, the answer is Yes! I have an '11 wrx and I want to get her wheels away from being so tucked up under the fender. I've searched through different Suby forums and read through many blogs and I plan to go with 15mm spacers; hubcentric of course. I'm not looking for cheap spacers and I won't pay for the most expensive either. Any recommendations? Also, any thoughts on lug nuts? Opened or closed, extended or regular? Help me ease my indecisiveness
    '11 WRX
    Drive and determination.
    Registered User Downshift_WRX's Avatar
    Mar 2013
    Baton Rouge, LA
    Not sure about 15mm but the 25mm I'm using worked great. Here's the ones I bought
    4pc 1" 25mm Hubcentric 5x100 Wheel Spacers for Subaru Impreza WRX 2 5 RS | eBay
    Mar 2013
    Oh ok. Are those 25mm installed there in your pics? What lug nuts are you using?
    '11 WRX
    Mar 2013
    Baton Rouge, LA
    Yes they are installed in the picture. I'm using stock lugs, the spacers are made with new studs that fit perfect for stock lugs. Are you running any lowering springs? Just so you know, I had to roll my rear fenders to keep them from rubbing. I'm running RCE blacks.
    Mar 2013
    Looks good bro! I don't have her lowered and don't plan to anytime soon. Just ordered a set. Will post pics. Thx! It's amazing that i got 80+ views but only one reply to a commonly questionable modification. It's like being stuck on the side of the road and people just passing you by...smh
    '11 WRX
