DIY: 2012 WRX: Use fog lights as DRL
Results 1 to 2 of 2
This is a discussion on DIY: 2012 WRX: Use fog lights as DRL within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; This was one of the first mods I planned after I purchased my WRX in 2012. I searched and couldn't ...
    Registered User ea126405's Avatar
    Nov 2011
    Corn Country
    This was one of the first mods I planned after I purchased my WRX in 2012. I searched and couldn't find a DYI, so I planned to research later, got busy with other stuff, blah, blah, blah, time passed. Then I found myself 10 months later ready to move. One more search and viola! I Found it here:
    DIY: 2012 WRX: Use fog lights as DRL - NASIOC
    This is a very simple mod and as long as you own some ramps, it is easy to perform from under the car.
    1. 1 screw/bolt and 2 plastic pop-rivets get you under car access on passenger side.
    2. Use 2 Tap Splice connectors
    .......one for Green DLR Wire (part of DLR resister circuit)
    .......one for White/Black wire (part of Fog circuit)
    3. Approximately 10" of 14 gauge wire between 2 taps.
    .......Could do with 6" or so, but I used more to keep it clean and have
    .......enough to cable tie to harness.
    4. Leave plug to resister (step-down 12VDC-6VDC) unplugged.
    .......I used tape to insulate this plug prior to cable-tieing it off to horn bracket.
    5. I also changed the fogs to Luminics Krypton Series JDM Yellow bulbs
    .......Performing step 1 on the driver's side gave access for the bulb change.
    After buttoning things up it looked like this:
    Car running, eBrake off:
    .......of course ebrake on no lights at all
    Car running headlights on:
    Car running, headlights on, fog lights on:
    .......fogs work on stalk switch, independently from the DRL function.
    The yellow DRL/fogs look much more yellow in person and the night time view will rock yellow fogs when needed.
    Thanks to OP, REBinc (NASIOC), for the write up!!
    '12 WRX Limited, 5-door -- Black
    Jul 2012
    South Florida
    Just what I was looking for! Thanks.
    2015 WRX - Crystal Black Silca
    Cobb Axess Tuner --BrenTuning ECU Solutions
    Cree LED replacement High/Low bulbs
    Pioneer NEX 4000, Alpine PDX 9V, JL Audio C5 650 front /rear components, JL Audio 10TW1-4: 10-inch Subwoofer, Axxess ASWC-1 Steering Wheel Control Adapter
