Results 1 to 5 of 5
This is a discussion on Hella horn install within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Anyone know if you can use the stock wiring setup for hella horns? The ones I bought didn't come with ...
    Registered User Undone10's Avatar
    Jul 2008
    Philly
    Hella horn install
    Anyone know if you can use the stock wiring setup for hella horns? The ones I bought didn't come with any wires. I don't know if they are supposed to.
    - 2011 WRB STI
    Cobb stage 2 tune ~ Invidia turbo back exhaust
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    They don't come with any wires. You need to either make or buy a harness. If you look in the thread in my Sig you'll find instructions for a DIY. & the only use for the stock wiring is you use it to wire the harness to the steering.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Jul 2008
    Philly
    Quote Originally Posted by rage-wrx View Post
    Thanks that sort of helps. I'm pretty bad when it comes to electrical stuff though so I'm still confused with only that diagram to go by. Maybe I'll just buy a harness.
    - 2011 WRB STI
    Aug 2010
    Yonkers/NYC
    The easy way out is to buy the harness. Try subimods or AD motorsports.
    If you think about DIY all you need to know is basic soldering.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
    Registered User free2be4ever7's Avatar
    Nov 2011
    chicago burbs
    If you click on my signature link I documented how I installed my hella horns.
