i removed his plastic piece that runs in the middle(the whole piece with the hoonigan sticker im talking about)
when you take off the side panel on the passenger side there is a screw that holds on this middle piece, you can pretty much rip it off once that screw is out. i used this to help me route the power wire. The ground i just routed thru the door again with the power wire and bolted it to the metal behind the side panel on the passenger side( this is a picture of the drivers side, but its similar on the passenger side. in this case it would be the phillps screw on the right of that big white sticker)
this picture shows where the wires will pop thru if routed thru the door grommet on passenger side.
the next steps!You than just have to bolt the ground on the passenger side the same way you did on the drivers side, but ground it to a hole in the metal dash using a nut and bolt on the passenger side. Run the red power wire thru the dash, stering column to get to the fuse #16 fuse tap you already have.
hook up the 2 power wires to fuse #16 and assemble the LED the same way you did on the drivers side, and with the ground andpower hooked up, see if it all works out before you put it all back together!
Here it is done!
MY MOST RECENT PROJECT! Bride Wrapped Armrest & Boots!+ STi Cupholders in a WRX!
STi Cupholder Console swap in a 08+ WRX! :)
LinkBack URL
About LinkBacks
one day ill fix it up so its clean
