I can't get used to how big the nose is - CRUNCH
Results 1 to 15 of 15
This is a discussion on I can't get used to how big the nose is - CRUNCH within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; So, I can't seem to get used to how big the nose hangs out on my car. Unfortunately, too many ...
    Registered User etnpnys's Avatar
    Dec 2011
    Olympia, WA
    So, I can't seem to get used to how big the nose hangs out on my car. Unfortunately, too many times now I have found myself scraping on curbs or something while parking. This morning, I actually even hit a little pole or something because I didn't see it - it was NEXT TO the curb I guess, but I digress.
    Anywhooo, what is the best way to fix this up? Goof Off or something? Maybe then a micro-abrasion thing like the PlastX stuff for headlights? Live with it? Touch it up? Get some of that Dr Color Chip stuff?
    Here's a pic of my ineptitude:
    "Ah, it is the fault of our science that it wants to explain all; and if it explain not, then it says there is nothing to explain."
    -Van Helsing, from Bram Stoker's ​Dracula
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Kinda hard to tell from the pic, but it looks like those scrapes removed some plastic - no polish or scratch-x is going to help. If it's just paint transfer (no gouges in the plastic, only paint from the pole left on the surface), you can try the scratch-x or take it to a detailer.
    Dec 2011
    Olympia, WA
    Yeah, I fully expect that it took some plastic with it. I hit it so hard I actually had to snap parts back together... I don't expect it to look like new after whatever you guys recommend (unless it's magical)...
    Dec 2011
    Pottstown PA
    on my 02 i pulled in my garage too far. hit my parts cabinet and had a metal flashlight fall nicely down and put a few dents in my hood
    Palmyra, NJ
    ha you should see my front bumper on my 2005. Its low as crap and I pop off panels and bumper trim and everything all the time. I gave up after awhile.
    I understand it's a new car though and you want to take care of it. Good thing is, there's no rust to deal with. Best thing to do is just find some matching touch up paint.
    Dec 2011
    Olympia, WA
    Gotcha. I appreciate the input. And "new" = 20,000 miles already! Dang...
    I think I'll probably get some of that Dr. Color Chip stuff - it's only $40 and looks like it does a fair job. And I'll probably be getting a front lip soon. And maybe I'll just learn to err on the side of caution, but I'm not holding my breath for that to sink in...
    Road Hazard STI*NG's Avatar
    Sep 2012
    Columbus, OH
    I used to do that all the time on my Eclipse. The STI has a much shorter nose and actually sits a bit higher.
    It might be worth getting a fine grade sand paper and smoothing it out a bit first, priming and doing a spray of the area. You should be able to color match it.
    Dec 2011
    Olympia, WA
    FWIW, I used some Goof Off or whatever to get rid of the paint markings and it looks a lot better. Still some plastic missing, but it's manageable now.
    That front bumper acts like a shovel when I'm in the dirt anyway, so I'm sure I'll be getting it replaced eventually.
    Jan 2012
    Philly Area
    I just noticed a nice crack on mine...damn things need a nose job!
    - Will
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Early on i figured out that I can tell where by lining up my sight. I look under the bottom of the driver side mirror, there is a spot when that lines up nicely with the bottom of the curb I'm nosing towards. Not so hard to tell when to stop. Try to find something like that. Of course that changes with changing the seat position or sitting differently, or slope in the drive surface...
    Registered User garzdos's Avatar
    Feb 2013
    Oregon
    I feel you pain...I only scraped the underside of my front, but it is hard to judge. And when I think I am doing a good job and stopping early enough I often find I went farther that I thought..but thankfully it has been over curbs lower than my front. I had great success with the subaru OEM touch up paint...mine is the same color as yours and it has been a perfect match.
    Dec 2011
    Olympia, WA
    Quote Originally Posted by Ingo View Post
    That's genius actually...
    Dec 2011
    Olympia, WA
    Quote Originally Posted by garzdos View Post
    Awesome - thanx for the recommendation! I think I'm going to end up getting some of that Dr Paint Chip Color stuff (or whatever it's called) also just in case. We all end up complaining about the "sandblasted" look after a while no matter what. And my 2012 already has 21k miles on it!
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    I'd be pretty screwed if I were any lower - I always stick my nose over :P
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Oct 2011
    Santa Ana, CA
    ^^Ass in first =)
    Posted from a fone.
