Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
This is a discussion on Need help with lights!! within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; disagree. its called "projector" for a reason, it throws light. they arent precison focused like a lazor beam. have my ...
    Jun 2012
    nj
    disagree. its called "projector" for a reason, it throws light. they arent precison focused like a lazor beam. have my headlight appart right now. the only thing in the projector is a ribbed mirrored surface reflecting out the front. with a plate twords the front so you dont get a direct view of the filamant. the problem is leds from a cheap website arent as bright as a burning filimant. superbright= $25 bucks. factory installed on a honda= $1,400. huge quality difference between the two. color what the allure for me buying them to match my hid headlights.
  2. #17
    Registered User younoleit's Avatar
    May 2012
    Does anyone have LEDs in their turn signals?
  3. #18
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Quote Originally Posted by njandy View Post
    I don't follow. What are you disagreeing with? I know your foglights aren't projectors, only your low beams are. That doesn't change the fact that LEDs won't focus properly in either one unless the assembly is specifically designed to use LEDs. There are some models out there now that offer LED headlights as OEM options.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
  4. #19
    Jun 2012
    nj
    i dont agree with you saying headlights wont focus the led bulb. the difference between the projector and say a regular assembly with just clear lens is the projector just shoots the light down twords the road and the regular light throws it everywere up in the sky and right at oncoming traffics face. leds will absolutley work in all fixtures but they arent nearly as bright. thats why they shouldnt be used. either way LEDS in a headlight is a bad idea. secondary lighting...who cares. i work with this stuff every day im an electrician and we retro fit alot of parking lot lights and outdoor lighting. the LEDs are rarey as bright as incandescent, hids, or high pressure sodium. LEDs are a relitively new technology that need a little more time to improve before they can be a direct replacement.
