Results 1 to 10 of 10
This is a discussion on Links for good lighting upgrades within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Sube newb here. Just picked up a 2013 WRX Base hatchback and I'm looking for ideas to upgrade the headlights. ...
    Registered User thebanker's Avatar
    Nov 2012
    SoCal
    OK so I've done some research. I've searched here and NASIOC. I've read Daniel Stern's site, and looked at the options. At this point, I'm looking for a good plug-and-play headlight bulb swap that requires as little modification as possible. The blue HID look isn't a necessity for me, but if it is a cooler color temperature, that would be a plus. What's the verdict for the best bang-for-your-buck halogen headlight upgrade? The Narva bulbs? HIR's? Does anyone have pics comparing the spread and color rendition of each bulb?
    If you have done a bulb swap and have good pics, post up a picture. Also, if this post is way out of line, and been covered ad infinitum, please kindly smack me on the nose with a newspaper.
    Thanks!
    - mikey
    2013 WRX | DGM | GR | FACTORY STOCK
    Nov 2012
    SoCal
    I found this list which is helpful for looking around online:
    2011-2013 Subaru WRX Light Bulb Sizing Chart
    Low Beam Headlight Bulb Size: H11
    High Beam Headlamp Light Bulb Size: 9005
    Parking Light Bulb Size: 1157A
    Front Turn Signal Light Bulb Size: 1157A
    Rear Turn Signal Light Bulb Size: 992 (7440A)
    Tail Light Bulb Size: 7443 or LED
    Stop Light Bulb Size: 7443 or LED
    High Mount Stop Light Bulb Size: 7506 or LED
    Fog/Driving Light Bulb Size: 9006
    License Plate Light Bulb Size: 168
    Back Up Light Bulb Size: 7440 or 921
    Cornering Light Bulb Size: 921
    Front Side Marker Light Bulb Size: 1157A
    Rear Side Marker Light Bulb Size: 168 or 7443
    Map Light Bulb Size: DE3175
    Dome Light Bulb Size: DE3175
    Trunk/Cargo Area Light Bulb Size: 2825
    - mikey
    Nov 2012
    SoCal
    Second question: BESIDES Daniel Stern, who I'm sure is a nice man, is there a preferred aftermarket vendor for buying replacement bulbs, LED's, etc for any of the above list?
    - mikey
    Daniel Stern had me buy bulbs that he didn't sell (over ones he did) because he felt they best suited my needs; customer service, at its finest.
    There's a reason everyone tells you to go to him...
    Jul 2012
    CT
    I went with the H9 conversion and used these bulbs:
    Philips H9 Standard Headlight Bulb, Pack of 1 : Amazon.com : Automotive
    They are definitely brighter, which is what I wanted. All you have to do is file down a tab in the connector. Look around the forum and you will find the procedure with pictures. If you are interested in the conversion it shouldn't take more than 15-20 minutes to do. Well worth it.
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Same here. He pointed me to a specific model that he didn't carry, and I ended up getting them on Amazon, I believe. I got my interior LEDs from SuperBrightLEDs.com as their website had the most information available for ensuring compatiblity with my car, and prices were reasonable.
    NOTE: If you intend to replace any interior LEDs, I highly recommend looking at the beam dispersion ratings SuperBrightLEDs posts for all their bulbs. When replacing incandescent bulbs with LEDs, you can end up with "hotspots" depending on application since incandescents have a wide beam spread and LEDs typically are more of a point light source. Choosing the wide-angle LEDs will help prevent this problem. I don't see any hotspots after my LED conversion.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Nov 2012
    SoCal
    Quote Originally Posted by mdkflip View Post
    I saw a DIY on this, to be clear, the modification is done to the connector on the bulb, not the car, right? Looks fairly simple, just shave off that one inner tab on the bulb's connector? (Not the connector on the wiring harness on the car)
    - mikey
    Registered User Rodman's Avatar
    May 2012
    CT
    Quote Originally Posted by thebanker View Post
    Correct, modification is done to the connector on the bulb, not your new shinny Rex.. This was my 1st mod. I like it
    Rod
    2012 DMG WRX base Sedan Cobb S1 93 Octane
    Older than dirt Mob#1
    "Just remember, with great power comes great responsibility" - rarrior
    Nov 2012
    SoCal
    Quote Originally Posted by Rambo View Post
    Thanks, and I don't plan on doing any LED swaps in the interior. The LED look tends to be too harsh, since most interior swaps create a cool white light.
    - mikey
    Nov 2012
    SoCal
    Quote Originally Posted by Rodman View Post
    Ok cool. I'll get my hands on some Philips H9's and check it out.
    - mikey
