doesn't seem right, i think you should probably get a new piece for that ball and socket joint
This is a discussion on problem with my retrofit within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I am retrofitting STI projectors in my 12 wrx, and ordered some extra headlights to do the retrofit on. One ...
I am retrofitting STI projectors in my 12 wrx, and ordered some extra headlights to do the retrofit on. One light was ok and the othe bezel inside was loose. I baked them and pulled the backings off, and saw that the ball and socket joint was out. I know that these are supposed to be in there very tight. I can just pop it in and out even with the top screw in. It takes a little force but nothing near what it should be. Im just wondering if there is a fix for this or if it will stay intact while driving and hitting bumps on the road? I think it will stay but not sure. PLease help
Uploaded with ImageShack.us
2012 SWP 5door Premium!!!
That pic looks normal to me... Are you trying to pop it in? or pop it out? It's there as a pivot for the light adjustment.
It (supposedly) takes a lot of effort to pop it out, but make sure you use even force or else you'll crack it right between the high/low beam reflectors.
One way to check is to set the up/down and left/right aim, pop the ball back in and then shake the light, if it pops out, then you have a problem, if not, then it should be fine... cause you shouldn't be going over bumps that hard in your car.
Another solution... Set the up/down | left/right aim so it's PERFECT, then put a dab of epoxy or superglue in the socket joint.
I don't think it's a replacement part you can order separate.
My validation...
2013 WRX Plasma Blue Pearl
