yes, everything will bolt right up. there will be new wiring but i dont think you'll need to cut and splice
This is a discussion on Another lighting question? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I am getting a new set of headlights for the correct retrofit and was planning on getting the kit from ...
I am getting a new set of headlights for the correct retrofit and was planning on getting the kit from the retrofit source.com. or just replacing the projectors with STI projectors. Do any of you know if the sti projector will bolt right up to where the old halogen projector was, and if all the wiring will connect? I don't want to cut and splice. I would like the sti projectors over the morimoto ones, only for the fact of them being from factory
Sent from my Galaxy Nexus using Tapatalk 2
2012 SWP 5door Premium!!!
