Results 1 to 6 of 6
This is a discussion on Remove spoiler and patch holes? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; I assume this isnt to hard but how hard is it to make the paint look nice afterwards?...
    Registered User dburke911's Avatar
    Sep 2012
    SC
    I disagree, specifically because you are asking.
    Since you are asking, I strongly recommend you swap trunks with someone rather than attempt to patch the holes in yours and paint it.
    There are trunk swap threads for this purpose; have a look around.
    Registered User Killerkanadian's Avatar
    Mar 2012
    Oklahoma
    Pay a professional.
    Sep 2012
    SC
    Thanks for the tips!
    Mar 2012
    Oklahoma
    I have mine off just to see if I like the look for the long run. I took it out and covered the holes with blue painters tape. Its even stormed and its lasted well with one little piece.
    Probably could glue some metal to the back of the hole, and then fill it with some bondo. Spray the trunk with a spray can of paint and a clear coat. Probably would cost about $60-80, but if it didn't look perfect, I would just be back to paying a professional to fix it anyways.
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    Ive done this numberous times, depending on the color and condition of the paint your in it 300-500, Pull off the spoiler, grind down the trunk, weld in some plugs, grind down, apply light weight plastic filler, prime, block, prime, mask off and wet sand blending areas, base coat, clear coat, some instances tri stage coat, bake, polish.
    Lead Wrench @ WTF Tuning, LLC
