Page 1 of 3 123 LastLast
Results 1 to 15 of 33
This is a discussion on Installed a set of Hella Supertones on my 2012 WRX * Pix * within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Installed a set of Hella Supertones powdercoated white with Subimods harness n bracket. Great deal from Subimods.com Need to clean ...
    Apr 2012
    Bay Area , CA
    Installed a set of Hella Supertones powdercoated white with Subimods harness n bracket. Great deal from Subimods.com Need to clean up the harness...
    Sound is loud and meaner... The stock horns were just wimpy in my opinion. Easy install , took off the front bumper in 5 mins.
    Apr 2012
    Bay Area , CA
    Does anyone know a better location for the relay ? I'm afraid water will get around
    Registered User gregroot198521's Avatar
    Feb 2011
    El Paso, TX
    I installed mine in the wheel well, above the fender liner.
    Hawkeye Alliance #1050
    Build Thread
    http://i1108.photobucket.com/albums/..._Signature.jpg
    Always dirty, never scurred......
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Nice. Very Storm Trooper-ey
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    Quote Originally Posted by Dova View Post
    I attached mine to the battery tie down.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Feb 2011
    El Paso, TX
    Contemplating installing a second set in mine. Not sure if I wanna do the subiemods harness for the second set though.....
    Build Thread
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    I put the relay dead center.. just use a good quality sealed relay. With the sport grill and the factory grill that center support piece should shield the relay well enough that it shouldn't matter.
    Just dont go submerging the car and I'm sure it wont be an issue at all.
    OH.. and be careful if you do ever change the relay for any odd reason. The terminals on the included hella relay are not standard config. If you do need to change it pay close attention to the terminal layout of the new relay and adjust the harness to match.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Apr 2012
    Bay Area , CA
    Quote Originally Posted by mangostick View Post
    Thanks for the advice. I'm using the Subimods harness with relay built in. The Hella relay were giving people problems so they included a new 5 pin relay.
    Apr 2012
    Bay Area , CA
    Yes. Much manlier than the stock wimpy horns.
    Dec 2011
    Pottstown PA
    looks good, like the white
    Registered User scarmack's Avatar
    Apr 2012
    Sharpsville, PA
    Me likey, I can't believe I haven't done this yet
    2012 Limited Black Pearl WRX
    My Build to Destruction
    52 Week Project
    Registered User bratte88's Avatar
    Apr 2012
    With there harness you just plug it into the horn up front and disconnect the side one on passenger?
    -Brian
    2012 SWP WRX hatch
    PERRIN TMIC (black) / PERRIN CAI (red) / PERRIN Radiator Shroud (red)
    Cobb Accessport / Invidia Q300 Catback / Invidia DP / SPT Boost Gauge
    Pioneer 7" Nav w/ backup camera / SPT STS / Red Hella's / Kartboy Bushing
    6K lowbeams 6K fogs 6k DRL / Grimmspeed Plate Relocation / Cobb Heat Shield
    Cobb Red Shift Knob / Rally Armor Mud Flaps / 08 STi center console swap
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    Quote Originally Posted by maus View Post
    Same. Mine is tucked in between the battery and fuse box.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    Oct 2010
    Man, I need to get into the wire harness business. $35 for what's essentially an extension cord?!
    It's my belief that soldering should be a basic car tinkering skill. You can make this harness with less than $5 in Radioshack parts, free if you keep such stuff stocked, as I do. This is the perfect project to get your feet wet on making your own harnesses. I've made my own for every electrical mod to date without a single failure or damage to any of them.
