2011 WRX side vent LED turn signal mod. - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
This is a discussion on 2011 WRX side vent LED turn signal mod. within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Great job! You've inspired me...
    Registered User SoFloRex's Avatar
    Jul 2012
    West Palm Beach
    Registered User 08WRXdan's Avatar
    Nov 2010
    Lancaster, NY
    The fender gaps for the STI are the same as the WRX. the part number is identical.
    If at first you don't succeed, go into boost. If you cant go into boost... no panties will be harmed. much less be sent to the rear seats.
    All else fails... put a disco roof in your car. E.v.e.r.y.o.n.e. loves going into a car to dance. Or... strobe them unconcious.
    Feb 2011
    Conesus , NY
    Looks great !
    Were did you get the LED's from ?
  5. #19
    Registered User Hoofhearted's Avatar
    Aug 2011
    Quote Originally Posted by Rowlem View Post
    Looks great !
    Auto zone.
    Sent from my PC36100 using Tapatalk 2
    2011 Base WRX
  6. #20
    Registered User etnpnys's Avatar
    Dec 2011
    Olympia, WA
    Happy thread resurrecting!
    "Connect the positive wire of the LED strip to the green wire if you want the LED strip to turn on and stay on when ever your parking nights are on and then flash when the turn signal is turned on. Connect the negative wire from the LED strip to the black wire going into the turn signal."
    Just got my LEDs for Christmas so lemme see if I understand...
    I turn on the headlights. These come on, right?
    With the headlights on and these lights on, I turn on the turn signal and that side blinks, right?
    Turn the headlights off and turn the turn signal on, these blink - right?
    "Ah, it is the fault of our science that it wants to explain all; and if it explain not, then it says there is nothing to explain."
    -Van Helsing, from Bram Stoker's ​Dracula
  7. #21
    May 2010
    Pittsburgh, PA
    The vents on the side are a mystery. Some cars have those flaps that block the vents.... some don't. Even within the model year it seems to change. Mine didn't. Other 11 STi's over on iwsti did.
    They look nice though, I like 'em at least. Always a fan of making turn signals more visible (as opposed to less with tinting). Of course, those would block my speed holes that I added behind that vent... they give me 20hp. Duh.
    EDIT: I missed the thread from teh dead part... For what it is worth though, adding those holes actually does create an airflow in that direction. I can put some cash on this after pulling out about a gallon buckets worth of dried up leaves from behind the fender well.
    2011 STi Build Log
  8. #22
    Aug 2011
    Quote Originally Posted by etnpnys View Post
    If you hook the positive wire of the LED to the green wire yes they will come on with the parking lights.
    When you turn off the parking lights they should come on with your turn signals.
    2011 Base WRX
  9. #23
    Dec 2011
    Olympia, WA
    Quote Originally Posted by Hoofhearted View Post
    Thanx - what about them blinking when the parking lights are also on? Will they do that also with the green wire?
  10. #24
    Aug 2011
    Yes they will blink but I think it will be alternating. So when the parking light is blinking off the LEDs will be on and vice versa.
    2011 Base WRX
  11. #25
    Dec 2011
    Olympia, WA
    That is EXACTLY what I was hoping for! Thank you for all your help! I may just be attacking this on my 4-day weekend right now
  12. #26
    Dec 2011
    Olympia, WA
    Ok I have them physically installed but not hooked up yet. I ran out of time and I'll do that part later. For now, I used the battery that came with them to take a few pictures.
    Now, my car doesn't have the vent blocking thing. I also didn't put the LEDs right up at the grill - I wanted more of a "glow" so I installed them back a little bit to let the light fill up the vent a little bit more smoothly. To do that, I had to shave off some little nubs that reinforce the spacers on the plastic using a razor blade. No big deal; I hope that makes sense. AND, if the vent is functional at all, I'm not blocking anything this way either! I just used the 3M tape that came with them and I added a little bit of LokTite silicone stuff to keep it in place just in case.
  13. #27
    Road Hazard STI*NG's Avatar
    Sep 2012
    Columbus, OH
    Very nice! Not sure if that is a functional vent on my STi but it sounds like you solved that problem in any case. I might be checking this out when the weather gets nicer.
  14. #28
    Aug 2011
    Nice garage.
    2011 Base WRX
  15. #29
    Dec 2011
    Olympia, WA
    Nice garage.
    lol Thanx
  16. #30
    Registered User 11blackwrx's Avatar
    Sep 2011
    Akron, OH
    thats awesome, nice job
    2011 Subaru WRX Premium
    1988 Ford Mustang GT
    2000 Jeep Wrangler TJ
