Resurrecting this thread.
Just got a quick question.
How did you guys route the cable? I'm trying to figure out how to get it from head unit to camera without any wires showing.
This is a discussion on INSTALLED BACK-UP CAMERA within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; shamrocker, how did your install go?...
shamrocker,
Subaru WRX 2011 Spark Silver Metallic
It's very simple. I routed the wire into the license plate light (made a notch so that it would still attach properly) through the hatch into the driver side rubber grommet (use a coat hanger) and into the headliner.
From the headliner, drop it down along the rear pillar then down under the removable spare tire panel. Then, go up through the back seat and under the door sill trim all the way up to under the steering wheel. It was pretty simple and I'm not very experienced with wiring. Good luck!
Hey thanks a lot. I got the same camera that was posted earlier so I'm going everything works out. I'm still not sure when I'm going to do this (still cold out) but if I run into any issues I'll be back. I'll also try and take as many pictures as possible for the new head unit and back up cam.
