do you have a writeup on install?
This is a discussion on 2011 WRX Bi-Xenon Retrofit within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; When I was looking for the car, I couldn't find a silver Limited 5 door anywhere so I ended up ...
When I was looking for the car, I couldn't find a silver Limited 5 door anywhere so I ended up with a Premium without the HID's. I had retrofitted another car in the past with TSX projectors so I went ahead and planned on retrofitting this car as soon as I got it.
Luckily, The Retrofit Source makes a complete plug and play HID retrofit specifically for the WRX. The kit included.
- Morimoto Bi-Xenon Mini Projectors
- Morimoto 4300k Capsules
- OEM Subaru Ballasts
- Wiring Harness (including relays to turn on bi-xenon hi-beams)
- Mounting brackets
You can find it here.
WRX Retrofit Kit
The car apart to remove the headlights
The projectors installed and on. I also decided to remove the orange reflector in the housing and install some silver bulbs that burn orange.
Blue flicker at the cutoff
Aligning the lamps
Bi-xenon hi-beams (regular hi-beams stay on as well)
Overall I am incredibly happy with the system especially given the ease of install once you get the headlights open given the included brackets. There was zero fabrication, just bolt up and go.
2012 SWP 5door Premium!!!
Very nice! One day I will get around to doing this
Sent from my Galaxy SIII using Tapatalk 2
2013 WRX Sedan DGM
-Paul
yeah i write up would be great, looks like it turned out well, where did you get the clear amber bulbs?
2011 Subaru WRX Premium
1988 Ford Mustang GT
2000 Jeep Wrangler TJ
you should spend the money and get some OSRAM CBI's. they are an amazing bulb....
they're super expensive.
i did mine too. it was worth it but so time consuming (6 hrs) doing it first time ever
