HOLY TRUNK. This process took me way longer than I anticipated, but hopefully you'll learn from my mistakes, and this process will be a lot easier for you guys.
2.5 Get another person. I chose my friend Jack.
3. Open the trunk, and remove your deck lid. Do it by taking out these 4 bolts.
BEFORE YOU DO THAT: REMOVE THE BRAKE LIGHT WIRE THAT RUNS ALONG THE RIGHT BRACKET.
The best way to remove the lid is have a person at each corner, take one bolt out each, then loosen the other one to halfway. At the same time, have both people hand screw the bolt out, and have their other hand supporting the wing. (Remember, it's open at this point.) We used our heads to help balance it until we could get our other hands on the edge. Make sure you have cardboard or something laid down to protect the wing when you put it down. Your car should look something like this:
ONLY IF YOU ARE REPLACING TORSION BARS:
REPEAT, ONLY IF YOU ARE REPLACING TORSION BARS:
Now come the torsion bars.
Taking these out is REALLY easy.
To put in, these are really hard to do, and 6 of my fingers were fine afterwards. The other 4 were the opposite of that.
You should see this:
Take a rubber mallet, and tap at the S curve, the part NOT in a bracket. Tap towards the opposite side. (If you are tapping at the left S curve, tap to the right.)
Once you can see that it's staying in just BARELY, get ready for a loud noise, and get out of the trunk if you're in it. (My first poor life choice was to stay inside). The torsion bars are under a lot of stress, so they like to get out of where they are. With the final tap, you'll hear a metal clang, and it will fall into the trunk. Your bracket will fall, so you can have someone/something hold it up so that it doesn't fly down. Then, do this on the other side.
STI Bars VS. WRX Bars:
They're thicker, and have a bigger bend. Sweet.
I painted mine black so that they matched the trunk, brackets, and looked good with the rest of the car.
When both bars are out, you have a decision to make. I found it a lot easier to put the deck lid on, THEN put the torsion bars on because i had something to weigh the brackets down to get the force to lock them in, and you will want to do this too.
IF YOU AREN'T DOING TORSION BARS, START HERE NOW:
4. Time for the new deck lid.
If you're small like me, you can set the trunk down where it belongs, then climb through the middle divider with a ratchet to attach it. If you aren't, we undid it and redid it that way just for you. Then we remembered we were supposed to take pictures.
You put the trunk on the brackets upright, and use one hand to hold it in place while putting a bolt in on each side simultaneously. Then to the other bolt, hold your breath, and let go. If you don't have torsion bars on cause you're swapping those too, you need a third person to hold the brackets up, or some impressive jerry rig to hold them up.
We don't have any pictures of that because there was only two of us.
Don't forget to reconnect the brake light wire!!!
Now shut the trunk and celebrate!!
Unless you're redoing torsion bars. You should keep reading.![]()
LinkBack URL
About LinkBacks
