09 Impreza: How to change fog lights?
Results 1 to 7 of 7
This is a discussion on 09 Impreza: How to change fog lights? within the Exterior & Appearance forums, part of the Tech & Modifying & General Repairs category; Does anybody know how to change the fog light bulbs in the 08/09 Impreza? The owner's manual says to take ...
    Sep 2008
    Does anybody know how to change the fog light bulbs in the 08/09 Impreza? The owner's manual says to take it to the dealer but all there are are some funny looking plastic clips that I do not want to break.
    The stock bulbs are useless and are of no use when driving; they only look nice to see 4 lights.
    Registered User Spincycle's Avatar
    Jul 2007
    Janesville, WI
    I believe you need to take them off from the rear, I had my bumper off to replace my headlights, and it looked to me like the twist about a 1/4 turn and pull out type of removal. If you pop out a few of the plastic clips I am sure you could reach up from behind and get them off without having to remove the whole bumper assembly. What kinds replacement bulb you planning to put in? I'd like to put something a lil more potent in mine also. Since getting my HID's installed, I have not even used them, because they help very little.
    Sep 2008
    Bulbs changed
    I used a pair of side cutters and worked the plastic plugs out, the bulbs were easily acceible from the backside. Be careful with the plastic plugs as they can be reused when the center pin is retracted.
    I installed the Sylvania Silverstars but they did not make a huge difference, i think it may be due to the plastic cover inside the fog light and the shape of the reflectors inside.
    Registered User 1sxysubi's Avatar
    Apr 2009
    yeah I did mine, pretty easy! I just used a flat head to pry those plastic plugs up in the middle and just pulled them out.... But what were they thinking? The fogs do nothing, I some better lamps in there and you still cant tell their on!!
    Anyone put HIDs in them yet????
    2008 WRX
    K&N Drop in
    Magnaflow exhaust----That is all.....
    Mar 2017
    Rio Rancho, NM
    I have a 2009 wrx sedan that has no fog lights. Just some black plastic mesh where the fog light holes are. Where can i find fog lights that will fit properly in the bumper openings? Thanks.
    Registered User 90Duck's Avatar
    Mar 2016
    Bend, Oregon
    Quote Originally Posted by GilGraue View Post
    I got some off eBay for under $70 for my daughters '09 Impreza just a couple of months ago, and there are still some available on there if you do a search. They come with a full wiring harness and a switch to mount on the dash. I watched the video on Subiespeed for installing fog lights on the '15 WRX and it was close enough that it worked on her '08 (thanks to Subaru for more evolution than revolution from model year to model year), and I had never attempted anything like that before. The bumper cover is really easy to remove with a few clips and bolts, which you will need to do to mount the lights in the holes after removing those mesh covers. No special tools are needed. Getting the little nuts and bolts aligned to mount the lights in the bumper was definitely the hardest part (the kits don't come with them, so I had to make a trip to Ace Hardware and spend a couple of bucks extra). I ended up using duct tape to hold the nut in place while trying to get the bolt started through them since there is not room for your fingers to hold it. The first one when easily, the second one was a PITA.
    Just changing the bulbs can be done three ways: by pulling off the bumper cover; popping out a clip or two and getting in through the fender liner, or; going in from below and unclipping/bolting the plastic covers down there. The lights don't do a whole lot for seeing down the road, but they look cool when you're done and it's kind of a fun way to spend a weekend day.
    Having aspirations is not the same thing as achieving them. - Mr. Regular
    Mar 2017
    Rio Rancho, NM
    Awesome thanks for the input. Definitely helpful and I'll be looking into getting some soon. Thanks!
    2009 WRX Sedan
    All stock except muffler delete
    Future plans: Intake, full exhaust, suspension, tune, bigger turbo
    New to the subaru scene. Looking for advise...
