ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Exterior & Appearance
Exterior & Appearance Exterior care, modifications, and pictures galore.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rate Thread Display Modes
Old 05-25-2009, 01:09 PM   #1 (permalink)
Custom splitter for Spearco TMIC
well i have been wanting to make one for a long time, so this afternoon i got off my lazy rear and made one. I always had a feeling that the 04-05 WRX scoop brought in plenty of air, it just needed to be directed in the right way and onto a proper intercooler. Already have the Spearco TMIC so I was set.
First i got some galvanized thin steel ducting. Aluminum would've been nice, but i couldn't find what i wanted. This was free
Got a few tools. Metal bender, point-punch, tin snips, and not pictured is also a sawzall with metal cutting blade, pop rivet gun, drill, bits, etc.
Then i traced and cut out the base piece. Mocked it up to the scoop to get the right fitment to drill the holes.
Then i purchased some all-weather stripping for garage doors (rubber and vinyl construction). Cut some curved pieces to fit up in the scoop to direct the air onto the scoop. I also cut some flanges to attach the weather stripping. I pop riveted it all together, and mocked it up again to be sure of fitment. Found that i need a few more pop rivets in a few places.
Heres how well the final product seals onto the TMIC.
You might notice i did NOT cut a hole for air to get to the turbo charger. I also wound up making a secondary heat shield to place around the first one, and honestly i don't think a tiny bit of air coming in from the scoop is going to do much to cool off a turbo beneath two heat shields.
Also without this hole in the splitter, the scoop will not loose pressure through that hole, forcing more of it through the TMIC (this is just an educated guess. I could be wrong)
If your wanting to make your own heres some tips.
1. Take your time to make sure all the holes line up. A drill press works nicely for making the holes.
2. Be careful! I cut myself at least 3 times with that stuff. Not bad, but it can be pretty sharp.
3. Seal between the scoop and the splitter as well. This will help keep a higher pressure above the TMIC. Which should force more air through it.
Also just to see how it worked, i just got back from a couple hard WOT runs and placed my hand on the scoop. It was nice and cool to the touch, but more importantly its nice and cool all over, not just in a spot or two like the stock splitter used to make it. and its 83 and blaring sun outside.
Ideally, in the future, I will use AutoCAD3D to design one that truly has optimal airflow. And make it look a little prettier. This is kinda rough, but it gets the job done quite well. Aftermarket splitters are another option, but im not gonna pay 100+$ for something that doesn't even make use of my entire intercooler. Now all 18"x6" of the TMIC gets used! woot!
xsnapshot is offline   Reply With Quote
Old 05-25-2009, 01:21 PM   #2 (permalink)
ClubWRX Grammar Czar
Sinister's Avatar
Send a message via AIM to Sinister
the air is all piling up at the rear because there isn't a middle fin. I would get the zero sports splitter.
__________________
- Kevin ....... '06 SGM WRX - VF39'd @ 293whp 346wtq 13.6 @ 98mph 1.8 60ft @ 6000ft Elevation
Your friendly Colorado Moderator - Colorado Member's Forum
Sponsored By: BreakThru Motorsports.com and WRXPro.com
AIM: SinisterSooby
Sinister is offline   Reply With Quote
Old 05-25-2009, 01:29 PM   #3 (permalink)
Quote:
well for it all piling up at rear, it sure is doing a nice job of keeping the front cool. I think, at speed, the whole scoop is become pressurized and thus getting flow. I might go back later and add a fin in the middle though. We'll see how it does.
Point is this cost me about 7$ and some time. All the materials i already had except for the weather stripping. And its doing a MUCH better job than the original.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
