STi under aero bits
Page 1 of 6 123456 LastLast
Results 1 to 15 of 88
This is a discussion on STi under aero bits within the Exterior and Appearance forums, part of the Tutorials & DIY category; The 05+ STi's come w/ some nice under aero cladding- this helps reduce lift at speed (and evidently may even ...
    Jul 2001
    Plains of Eastern Montana
    STi under aero bits
    The 05+ STi's come w/ some nice under aero cladding- this helps reduce lift at speed (and evidently may even help gas mileage a smidge)
    Here the pieces I'm talking about
    Here the parts you need
    The aero pieces are
    56411FE000 and 56411FE010, you'll also need 18 plastic clips (order 20 so you have a couple spares) 909130059 and two 6mm bolts 5770KC000 (I'd order four to have a coiple spares).
    In addition you'll need a drill, good asst of bits including 13/64ths and 3/8ths, center punch, sharpie (red worked good), a tap for a 6mmx100, duct tape
    Pics of the aero piece, plastic clips and bolts
    Jul 2001
    OK lets get started First you need the car on jack stands, the higher the better- you'll need a little elbow room. Next pick a side to start the piece are clearly marked left and right.
    You start by lining the front up and sliding it into the end of the subframe- it should stay (but be hanging)
    Jul 2001
    Now orientate the rest of the piece- it should be vrey close to flush to the side- you'll see some half circles the piece fits around- this is where the duct tape comes in- get everything aligned nicely and duct the piece up so it stays up on it's own.
    Jul 2001
    Now with everything carefully lines up (the piece fits amazing well to the contours of the chassis) mark the holes w/ your sharpie- I started w/ the two furthest back to get it secure.
    Next you'll drill- the center punch won't do you much good on most of the holes as it's got a rubber coating underneath. The two exception are the hole drilled into the subframe and the hole that will be tapped for the bolt. Use a small bit and step up to 3/8" (the holes could probably a 64th larger- but I'd rather have them tight). The pilot hole needs to be center well for the other drilling to be accurate. I used three bits for each hole (except the tapped hole)- seemed to work good.
    Jul 2001
    Put a couple of clips in the rear holes, do the same for the front- it should be pretty snug and in place now. Repeat for the rest of the holes, except the one I have pictured as the 6mm bolt.
    Jul 2001
    You should have nine clips in now and one remaining- you need to mark and center punch the center of the hole- use a small bit to drill a pilot and then the hole needs to be drilled to 13/64ths. You'll find your drilling through two layers of metal on this hole. After it's drilled, you'll need to tap it w/ a 6mmx100 tap. Get the tap good and straight and go slow, backing off a little every turn or two.
    Registered User WRX13oy's Avatar
    Jul 2003
    SOCAL!! 91752
    cool. how much did you get them for?
    SOCAL F4#02 OG member
    2002 PSM WRX stage 6
    2007 Kawasaki Ninja ZX6R
    Jul 2001
    Now the piece should be fully installed- remove it (I know it's in already) and spray spray a little primer in each hole. Let the paint dry (go start on the other side )
    That's about it- a few pics of them installed.
    no under view of the finished product on your car liek the original picture?
    nice write up. Now go clean your car.
    Jul 2001
    try that one again
    Jul 2001
    The side peices + harware were a little over $100 total.
    I'll have a write up on the diffuser install later this week
    Sep 2004
    West of the Mississippi
    great write-up bigsky!!! thx!!
    Registered User kessler89's Avatar
    May 2004
    NW Ohio
    nice write up big sky, good god your car is dirty!! i'd like to do this to my car sometime in the near future along with the rear diffuser, i'll keep this writeup in mind
    Aspen white/gold 03 sedan *SOLD*
    Aspen white/gold 06 STi STG2 Bailey ProTuned
    Registered User coolblue04's Avatar
    Mar 2003
    near Toledo, OH
    Excellent writeup. Did you notice any difference?
    Tuned Perfection Autosports
    2005 Sti Widebody
    Jul 2001
    Haven't even been out of town yet- got a trip planned to the "big city" -possibly this weekend. I keep close tabs on my gas mileage- I'll be sure to monitor (and report) any differences if I see them.
