STi under aero bits - Page 6
Page 6 of 6 FirstFirst 123456
Results 76 to 88 of 88
This is a discussion on STi under aero bits within the Exterior and Appearance forums, part of the Tutorials & DIY category; Might be building my own custom under aero or installing a few of these pieces *subscribed* for ref...
  1. #76
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  3. #77
    Registered User kessler89's Avatar
    May 2004
    NW Ohio
    bringin this baby back from the dead, anyone know or confirm if the side aero pieces will fit on the GC chassis? gas just hit $3.50 here and i wanna squeeze every last mpg out of my DD
    if you dont know, what do ya think? think they'll work?
    Aspen white/gold 03 sedan *SOLD*
    Aspen white/gold 06 STi STG2 Bailey ProTuned
  4. #78
    Registered User spelk3's Avatar
    Aug 2002
    Mountain View, CA
    Question ALK mounting?
    Has anyone mounted these with an ALK?
    With the ALK the front subframe is mounted using spacers. Did you trim the aero panel where it attaches to the subframe so the front edge of the panel lies flush or mount it as is with the front edge held high by the subframe?
    Update:
    I decided to trim the panels to get a flush fit.
  6. #79
    Registered User jaqattack02's Avatar
    Sep 2005
    Richmond, Va
    Just thought I would mention that Subaru Genuine Parts sells the 2 side pieces as a kit that includes all the mounting hardware.
    https://www.subarugenuineparts.com/p...oducts_id=1158
    Blobeye Syndicate #035
    Cobb Stage 2
  7. #80
    Jul 2001
    Plains of Eastern Montana
    that makes it easy
  8. #81
    Apr 2008
    teh OC
    i got the kit from SGP this week.
    Their directions are slightly different. they provide a total of 4 bolts, 2 screws and the rest are plastic clips.
    instead of a 6mm bolt for big sky's location, they have a screw instead. 6mm bolts go in the front most outside and rearmost inside holes. i found that there's already a threaded hole in the front bolt hole...the rear location has a hole as well, but no threads. additionally, it's way too big for the 6mm bolt they've provided. you'll need to use a clip for that or get a bigger bolt and tap.
    i'm thinking of just using that rear bolt to secure where the screw would go instead and using a clips for the rear.
    "Let the ingorance die with the ignorant"
  9. #82
    Jul 2001
    possible it might vary slightly on what year you have (as to what is available on "bolting" it up)- main thing is getting it in there secure
  10. #83
    Sep 2004
    West of the Mississippi
    part # 56410FE061- Graham at japanparts.com said they've added it to their site
    unistalled
    installed
    yyyeeeaahhh i'm bumping an old thread. did you have to drill or tap for the nut into the chassis when you installed this?
  11. #84
    Jul 2001
    iirc that piece didn't require any drilling/tapping, the two longer piece do though
  12. #85
    Sep 2004
    thx brotha. i've got the long pieces on already. just received the tranny cover.
  13. #86
    Feb 2012
    Sorry to bring back an old thread. I just installed the sides and the rear diffuser with the cusco install kit. My question is though can I use the tranny cover on the automatic?
  14. #87
    Registered User AgentH's Avatar
    Feb 2005
    Philadelphia Area
    I finally did this on my wagon!
    I got a set of these shipped to me from a junk yard in CA for basically nothing. they were a bit mangled, but with a hot air gun and some fiberglass, they were back in relatively good shape. I followed bigsky's instruction except I drilled the pilot holes with the pieces taped to the bottom. I then removed the panal and drilled the larger holes for the clips that go on the outer corners of the panel. I put the panel in place held by the clips and made sure the other pilot holes were in the right spot.
    My subframe is a little squished, possibly from a jack, so instead of placing the clip in a hole in the sub frame, I drilled 2 holes and used a zip tie. Since the subframe is squished, I couldn't get a clip to bottom out.
    It would be cool, but I doubt I'll get a large front undertray or a diffuser. I doubt without those, I'll notice any difference in the way my car handles. But ya never know...
    2nd WRX...
    More than meets the eye.
  15. #88
    Jul 2001
    Sweet- glad some of these older threads are still helping out
