STi under aero bits - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 88
This is a discussion on STi under aero bits within the Exterior and Appearance forums, part of the Tutorials & DIY category; no extra noise from mine- in town or out...
  1. #61
    Jul 2001
    Plains of Eastern Montana
  3. #62
    Jul 2005
    I haven't posted on this forum in a LONG time.
    I found this link on saab92x.com. Just ordered mine and they will be going on hopefully next week with some other goodies.
    Phil from Element mentioned to me how squirrly the rear-end got at high speeds because I have a wagon, so I've been planning on a mod to improve the aerodynamics. Hopefully this will be what I'm looking for.
  4. #63
    Jul 2001
    Let us know if it works for you
  6. #64
    Registered User chimchim's Avatar
    May 2005
    SF Bay Area , CA
    Hey... where are you guys buying the side under bits? I can only find the rear diffuser piece at subarugenuineparts and other places.
  7. #65
    Jul 2001
    dealer- they are oe pieces off of the 05+ STi -part #'s listed at the begining Jamie at subarugenuineparts can get them too- maybe cheaper than your dealer- just give her the part #'s
  8. #66
    May 2005
    SF Bay Area , CA
    I looked under my 06 WRX wagon where the side under pieces would go... and it looks quite smooth under there. So... are the side under panels more for evening out the depth of the underside to be flush with the edge of the car?
    It's not like there are a lot of things sticking out down that that the panels actually cover up. The things that do stick out the most (suspension arms, exhaust) can't be covered up. The diffuser, on the other hand seems to make a smoother path over bits and bobs of the section from the rear axels back.
    Anyways, I'm wondering if the rear diffuser itself is effective enough or if it's only worth it (as far as it does work) with the side pieces. I understand that there's a camp of thought that says none of this stuff means anything. However, I try to have a sensitive butt dyno and even small differences are appreciated; and it's just fun to do.
  9. #67
    Jul 2001
    I'm a believer in that every little bit helps- so if your only doing the rear diffuser it's better than not having anything.
    While it's relatively smooth where the side panels go- it's also a rather largish "pocket" which can cause lift- the side pieces gets rid of those voids.
    I'd avoid camping where anyone thinks that smoothing out the underside will not reduce lift
  10. #68
    Registered User heyitznosaj's Avatar
    Apr 2007
    Quincy, MA
    I'm having trouble installing the STi rear diffuser on my 07 WRX. I have no clue where to mount the silver brackets. Am I suppose to drill into the spare tire tray?
    2007 OBP WRX LTD
    Cobb Accessport v2 Stage 2
    McCulloch 5000K HIDs h7
    DDM Slim 3000K HIDs h3
    HKS Carbon-Ti Exhaust
    Whiteline 24mm adj. FSB
    Invidia v2 bellmouth downpipe
    Pioneer Avic-D3 w/ CD-I200 Ipod cable & CD-R55 remote
  11. #69
    Jul 2003
    Cerritos
    just got my under panels on yesterday.
    half way done.
    all done.
  12. #70
    Apr 2007
    Quincy, MA
    Quote Originally Posted by heyitznosaj View Post
    anyone?
    2007 OBP WRX LTD
  13. #71
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Have you tried going to a deaer and crawling under a new STi to see how it is mounted? Sorry...that's all I can think of.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  14. #72
    Jul 2001
    the oe brackets you have are welded in the new cars- you can have them welded (obviously make damn sure they are in the correct spot before doing so)- they alos can be bolted in as well- necessitates drilling into the spare tire well- again measure 3 times drill once
  15. #73
    Apr 2007
    Quincy, MA
    The bracket just doesn't line up to anything. I might swing by a dealer and take a peak under a STi. Just hope there are no cops around . Could anyone save me the trouble with pics?
    2007 OBP WRX LTD
  16. #74
    Jun 2007
    Great Salt City of Utah
    This is a dope post.
    I custom fabed me a skid plate
    It was originaly made out of 3/16" SS plate but it weighed 40lbs. You could jack the whole car up on it without it bending
    My new one is some 16gadge it works good but that vented on is somthing to consider. I work for a steel shop so it would be easy to make.
  17. #75
    Jul 2001
    search here and nasioc for diffuser brackets- there should be some pics floating around
    pics will help w/ general orientation, it's still going to take a lot of futzing/measuring to get them aligned exactly right. maybe some two sided sticky tape so you can stick them up and move them around some- checking w/ the diffuser that the holes line up
    also having the rear bracket attached will give you a good idea where the other three need to be
