Fog Light Mod
Results 1 to 15 of 20
This is a discussion on Fog Light Mod within the Exterior and Appearance forums, part of the Tutorials & DIY category; Im wondering if anyone knows a way to turn just the fog lights on with out having the other lights ...
    Jun 2005
    ct
    Fog Light Mod
    Im wondering if anyone knows a way to turn just the fog lights on with out having the other lights come on. ive seen other cars (non wrx) with just the bottom set of fog lights on and it looks preety cool. im curious if theres a way we can do it too.
    vf22 Stage IIII wagon of DOOM
    glen cove
    i did this on my old mx6. What you have to do is trick the button to thinking the lights are on. for instance my mx6 there were 3 wires(ground, constant power, and a power line that turns on once the headlights are on). all i did was cut the constant and weld or connect that to the wire for the headlight so there is always power running to it, therefore there is always power runnin to the fogs. hope that helps!
    Jun 2005
    ct
    that sounds like it might just work. thanks for the info
    Registered User hellbilly1342's Avatar
    Dec 2005
    but what about the daytime running lights? those are still gonna be on. any way to turn those off?
    Registered User TOOFAST88's Avatar
    Oct 2005
    Champaign/Buffalo Grove, IL
    Quote Originally Posted by hellbilly1342
    The drl connection is behind your glove box, simply disconnect it. I'm not sure the name of the thread, but if you search a little you'll find a picture of it. Takes all of two minutes.
    COBBS!.....We got COBBS everywhere meng! COBBS, COBBS, COBBS!
    Blobeye Syndicate #2
    RYB - 01
    "RALLY ON"
    Quote Originally Posted by StreetSlider
    Hellen Keller's favorite color is Blobeye Syndicate.
    Dec 2005
    Quote Originally Posted by TOOFAST88
    thanks, i realized my mistake for asking before searching right after i posted that. I did the search and I found the thread.
    God I feel like such a noob
    Oct 2005
    No worries, I've been meaning to do this little mod for quite some time, but I haven't gotten around to it. Good luck!
    RYB - 01
    "RALLY ON"
    glen cove
    easier way to do it is under the hood there is a plug by the boost solenoid..........only works with the stock headlights tho so if u have aftermarket u have to disconnect it behind the glove box
    Jun 2005
    ct
    Quote Originally Posted by joelax4
    i have stock head lights. so can any one confirm if the 3 wires behind the god light swithc and slicing into constant power will work? like the fog lights will come on with just hitting the fog light button?
    glen cove
    id try it but i dont have fogs anymore
    Registered User volcomsoldier19's Avatar
    Mar 2005
    SoCal, Whales ******
    I have done the actual fog light mod, having full manual control. it's pretty kool but I think i got crappy bulbs off ebay, they keep burning out, i got H3's from some AZN guy in monrovia....hmm don't buy from him
    Quote Originally Posted by ansonowicz View Post
    So if I'm stuck in a rut or something, it's mostly because I made a wrong decision somewhere and I need to correct myself out of it.
    Jun 2005
    ct
    Quote Originally Posted by volcomsoldier19
    want to make a little write up on how to do it?
    Mar 2005
    Quote Originally Posted by rbwrx
    i may when i get time, however i doubt it will top my fuel filter write up
    Oct 2005
    For the fogs to work independently, I understand that instead of splicing the red w/ green striped wire into the orange wire, you need to splice it into something that will give a constant 12V, such as something that is powered whenever the inginition switch is on. Unfortunately, I don't know exaclty which wire that is, otherwise I'd be all over this mod.
    RYB - 01
    "RALLY ON"
    glen cove
    jus go to a car shop(ie pep boys) and get one of those things that look like a screw driver, and u ground it and put the tip on the wire and if it lights up that means u have power!
