ok...take back EVERYTHING i said about my car for the past 6 months (BELT TENSION)
Results 1 to 3 of 3
This is a discussion on ok...take back EVERYTHING i said about my car for the past 6 months (BELT TENSION) within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; so i'm changing the oil tonight, and as i turn on the car to let it idle and get the ...
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    so i'm changing the oil tonight, and as i turn on the car to let it idle and get the oil moving, i notice a weird sound comming from near the alternator. i look down and...."HOLY crap!!" the bolt to one of the smaller pulleys was somewhat loose, and the tension in the belts had tilted the pulley upwards, oh, say about 15-20 degrees!!!! yikes! it was rubbing up agains that thing that held it to the other pulley. so i turned off the car, tightened the bolt so the pulley would be aligned (damn near stripped the bolt in the process) and wow, the car runs amazingly smooth now
    i took it for a test drive, and i noticed a couple of significant changes
    1. the car revs faster - the throttle response is quicker than before
    2. the car doesn't vibrate anymore; before, it would be vibrate and shake alot under idle, as would the engine block - now its perfectly still (until i press on the gas, of course)
    3. less hesitation under acceleration, and smoother upshifts and downshifts - it feels like i did the grounding mod all over again hehe. forget about what i said about the grounding wires not doing anything - it must've been the pulley that was messing everything up.
    4. remember that damn a/c im always complaining about? well now, the a/c stays on all the time (or at least significantly moreso) and doesn't turn off when i'm at a stoplight or under hard revs
    honestly, it feels like a whole new car again - everything improved....or at least its back to the way it was when i first installed everything (cause i bet that the pulley became loose overtime, so i didn't really notice the deterioration until now)
    i fixed my car...woohoo!!!!!
    -Robert
    Silver 911
    WRX's older brother
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Glad you caught that loose bolt before it became a real problem. Grats on having a "new" car!
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Arrow
    All members: when installing a pulley TENSION THE BELTS
    Check them a dozen times according to the MANUAL.
    This is no joke, if PK drove his car like that much longer serious engine damage would have almost CERTAINLY occured.
    -Jim
