ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Community - Meet other Enthusiasts > Everyday Impreza Talk
Everyday Impreza Talk If it doesn't quite fit in any other forum, but it's related to the club in someway, discuss it here. General suggestions, questions, and comments welcome.
Advertise On ClubWRX
Welcome to the ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums.
Welcome to the ClubWRX.net Subaru Impreza Enthusiast Site. ClubWRX.net is a forum based online community for people to hang out, have fun, and gain lot of valuable knowledge about anything related to the WRX. You can learn more about ClubWRX.net here.
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and access our other FREE features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload your own photos and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact support.
(Registered Users of this site do not see this ad.)
Reply
Thread Tools Rating: Thread Rating: 14 votes, 4.29 average. Display Modes
Old 08-20-2002, 03:58 PM   #31
Gaspipe
Gaspipe's Avatar
  • ENGINE:
    VF30 turbo
    STi injectors
    Vishnu underdrive crank pulley
    Perrin fuel rails
    255 lph fuel pump
    TurboXS turbo back
    Maxim Works header
    Wrapped downpipe
    TurboXS Version 1 TMIC & silicone hoses
    Silicone IC to TB hose
    UTEC
    TurboXS ABC
    Autometer EGT
    CHASSIS:
    Prodrive P7 17x7
    Kumho 712 Ecsta 225/45x17
    Cusco F & R swaybars
    StopTech big front brakes
    Front stainless brake lines
    STi V7 RA struts (red ones) & springs
    STi upper strut mounts
    STi rear strut brace
    STi V7 front lip
    STi hood scoop
    STi short shifter
I run 17.5 psi with 93 octane pump fuel. I use Mobil 1 synthetic lubes and have had no issues. I bought a BEL 985 Vector radar detector - these should come with the car. The clutch and drivetrain are holding up fine, but the tranny ratios absolutely stink. They might be a lot more useable with 4.44 diffs, but someday I need to get different ratios. Maybe STi trannies will become reasonably priced in the future. They cost more than BMW Getrags now.
It's considerably faster and handles much better compared to as it was from the dealer.
__________________
Gaspipe
Faster is Better
'02 WRX - Stage 4, SOLD!
'97 BMW M3
'88 BMW M3
'87 BMW M6
'88 BMW 750iL
Gaspipe is offline   Reply With Quote
Old 08-22-2002, 02:56 PM   #32
wrxlarc
wrxlarc's Avatar
Factory Options
Auto-dimming Rear View Mirror w/Compass
Turbo gauge
Security upgrade
Spoiler
Hacks
3/16" solenoid mod
Complete trunk debage
Front emblem mod (painted blue)
OEM Uppipe GUTTED
Removed DRL Module
Silencer/milkjug removal mod
Suspension/Grip/Brakes
Alignment and corner balance from West End Alignment, Gardena CA
Carbotech Bobcat brake pads front and rear
Cusco front and rear sway bars
Cusco front and rear type OS aluminum strut bars
Cusco front lower arm bar ver. II
Goodridge stainless steel braided breaklines w/Speed Bleeders
JIC FLT-A2 Coilovers 7kg/5kg U.S. Spec
Motul RBF 600 brake fluid
Poltec heavy duty adjustable endlinks, front and rear, pillowball
Poltec aluminum (w/steel ends) adjustable lateral links, pillowball
Rota SDRs steel grey 17"x7.5" w/ Falken Azenis Sport 225x45x17
Rotora slotted rotors
STi Aluminum Control Arms
Whiteline ALK
Whiteline Diff Lock Kit - KSB751
Whiteline Steering Rack Bushings - KSR202
Performance
Kartboy shifter bushings
Mobil 1 synthetic @ 9500 miles
NGK BKR7E, coppers, 1 step colder
Perrin crank pulley
Perrin short shift adapter
Prodrive WR Sport Muffler
Samco silicon intercooler hoses
STi Tranny Mount Group N
STi Engine Mounts Group N
TXS Stealth Exhaust (down pipe, hi-flow cat, mid pipe)
Electronics/Gauges/Lights
Apexi turbo timer
Autometer bezel
EDM STi Lights
Omori "WRX Look" Gauges
- Electrical Oil Pressure 52mm
- Electrical EGT 52mm
- Mechanical Boost 45mm
Miscellaneous
Aluminum "Impreza" front license plate cover
Aluminum deadpedal *bling*
Gruppe-s.com radiator shroud
Kartboy exhaust hangers
OEM front lip
Painted side skirts
Prodrive knob (black)
SpeedMonkee.com grounding kit
STi hoodscoop
List
JDM V7 TMIC
ECU Reflash
2nd set of wheels and tires
Removed/Replaced
HKS SS-BOV
Kartboy solid rear droplinks
K&N drop-in panel filter
__________________
'02 WRX Sedan :: Platinum Silver :: 5 Speed : : Mods
wrxlarc is offline   Reply With Quote
Old 08-22-2002, 08:34 PM   #33
Weasel 555
Scooby Hooligan
Weasel 555's Avatar
Send a message via AIM to Weasel 555
Smile Stuff in my rex...
WRBlue rex....
Inside:
3 Greddy 52mm gauges Boost,EGT,Oil Pressure
Apexi SAFC
HKS EVC IV
Prodrive ECU
SoUK Stainless steel "Impreza" inner door pieces
SOA "fake"CF trim
STi JDM V7 seats
Outside:
SOA Bodykit
STi grill
Scoobysport CF wing
Orciari Headlights
Hella supertones(behind grill)
STi hoodscoop
Prodrive/STi V7 suspension
Cusco front and rear swaybars
Cusco Front and Rear Tower bars
MRT endlinks
Subaru 4 pots with porterfield pads
Dba slotted/cross drilled rotors
Goodridge braided brake lines front and rear
Inside Engine bay:
GGR Up-pipe
Scoobysport down-pipe going to WRSport muffler
IHI VF23 ported and polished
STi underscoop
Samco intercooler, radiator and intake hoses
Autospeed Performance lightened pulley
STi JDM intercooler
STi 550cc injectors
Parallel Fuel rails
Inside gearbox:
Exedy 40% stronger clutch
Exedy Lightened flywheel
car dynoed at pruven performance
at 16 lbs of boost 310hp and 310 lb/ft torque at the wheels at 4000rpm
Weasel 555 is online now   Reply With Quote
Old 08-26-2002, 03:36 PM   #34
bobgrice
Send a message via AIM to bobgrice
Delivered in April, 2001 with the following:
STi short shifter
Gauge pod (sold)
Upgraded speakers
Subwoofer
Since then, modifications are:
Silencer removed
Samco inlet hose
double secret ported TD04
Samco IC hoses
ported IC elbows
ported & polished TB
knife-edged TB plate
colder NGK plugs
custom up-pipe
BPM GT turbo back
Hallman MBC
earthing mod
Vishnu custom Unichip
Redline tranny fluid
STi motor mounts
STi tranny mount
STi short shifter
Lo-Tek A-pillar pod
Defi dash gauge pod
Omori EGT gauge
Omori Oil Pressure gauge
Omori Boost gauge
Omori Oil Temperature gauge
Omoir Fuel Pressure gauge
Omex sequential shift light
(all Omori gauges have auxiliary LED warning lights mounted next to cupholder with buzzer)
AutoMeter A/F gauge w/dedicated O2 sensor in downpipe
Hardwired Valentine 1
DMS Gold 40 coilovers
STi top mounts
Whiteline rear adjustable sway bar
Whiteline front sway bar (not installed)
Whiteline ALK
17" BBS RK with Kumho ECSTA V700 in 225/45-17
Wow. I've spent too much money on this thing...and I'm sure I'm not done!
bobgrice is offline   Reply With Quote
Old 09-04-2002, 11:00 AM   #35
wraven
Location: North Central Washington State--the drylands :)
[QUOTE]Originally posted by bedabi
**Stongard clear bra; [QUOTE]
Hey bedabi,
How do you like your Stongard clear bra? I have the headlight and foglight kit, and it has saved me considerable moaning and whining. Seriously thinking about getting the whole big kit.
Thanks.
__________________
Best regards,
wraven
www.whiteravendata.com
'02 WRX sedan, WRBP, 4EAT, Cobb Club Spec, other mods and pics at:
http://www.whiteravendata.com/my_wrx.htm
wraven is offline   Reply With Quote
Old 09-09-2002, 01:56 PM   #36
Jazz
just a few things:
Engine: GFB lightened under drive pulley kit, synthetic oil
Intake: K&N panel filter
Turbo system: Samco intercooler hoses, GFB BOV
Exhaust: MRT flex up pipe.
Drive train: synthetic tranny fluid and rear diff.
Suspension: Cusco front and rear anti-sway bar, MRT rear end links, Cusco front strut tower stiffener, Dunlop SP sport 5000.
__________________
Silver Wagon- Rally Tarmac
UTEC stage 1, MRT Up pipe, GFB pulley kit, Samco IC hoses, GFB BOV, GReddy boost gauge
Prodrive P1, Tein wagon coilovers, MRT strut tops, Cusco front and rear anti sway bars, Cusco strut tower stiffener, MRT end link front, STI lateral links and trailing arms pillow ball type.
Factory painted side skirts
Jazz is offline   Reply With Quote
Old 09-10-2002, 08:34 AM   #37
Ineedboost
My WRX Mods
2002 Platinum Silver WRX 5spd MT
PE1818 Turbo
GReddy FMIC
Blitz BOV
GReddy Intake
GReddy Profec B
GReddy Turbo Timer
Apex Super AFC
Custom Uppipe
GReddy Evolution Exhaust
Short Throw Shifter
Tanabe Coilovers
Cusco Front Sway Bar
Cusco Rear Sway Bar
Cusco Front Strut Bar
Cusco Rear Strut Bar
Bridgestone SO3's 215/45/17
Volk Racing CE28N Wheels
Defi Center Gauge Pod
Greddy EGT Gauge
Greddy Turbo Gauge
Greddy Oil Temp Gauge
Momo Race Air Shift Knob
JL Audio 2 10" Speaker Subwoofer Box / JL Audio Amp
Boston Component Speakers
Valentine One Radar Detector
GReddy Liscence Plate Holder
GReddy Seatbelt Pads
LoJack Alarm System
I think thats it.
__________________
Take it to the track A$$Monkey !
Ineedboost is offline   Reply With Quote
Old 09-15-2002, 11:21 PM   #38
Ronin2121
Well, here goes:
PE1818f
Greddy FMIC
Greddy Airnix Intake
Thermotec IC wrap
Forge 100% BOV
Blitz SBC-ID
Scooby Sport Turboback
STi Radiator Cap
Radiator Splitter
STi Injectors
Walbro Fuel Pump
Vishnu Stage 0
Greddy Catch Can
STi Hood Scoop
Sti Mesh Foglight Covers (replica)
Clear headlight mod
Silvervision Amber/Chrome turn signals
Clear Side Marker Lens
Rota Tarmac's/Falken Azenis
Axxis Ultimate brake pads
20% Window Tint
Infinity Kappa's (frt & rear)
Infinity Bass Link
MTX Amp
Dynamat Extreme (trunk)
Kart Boy SS & Knob
Color Matched Side Skirts
White line lowering springs
Cusco Strut Bars (front & rear)
Cusco Adj. Rear Sway Bar
Vivid Solid End Links
AutoMeter Gauges (boost,oil temp,oil pressure,egt,clock,air/fuel)
Lo-tek A-Pillar Pod
Indiglo White Faced Gauges
Grounding Mod
Escort 8500
Nos...Nitrous Oxide
Nos Purge Kit
Nos Bottle Warmer
Nos Remote Bottle Opener
Nos Covered Switches
Next:
Upgrade Engine Management
Brakes
Todd
Ronin2121 is offline   Reply With Quote
Old 09-20-2002, 08:08 PM   #39
MJU1983
MJU1983's Avatar
Send a message via AIM to MJU1983
Factory junk:
Speaker Upgrade
Subwoofer
Wing
Short Throw
STi shift knob
Boost gauge
Performance Mods:
Modified IHI VF30
565cc STi injectors
Walbro 255lph fuel pump GSS342
Perrin Short Ram Intake
APS D/R 500 FMIC
HKS carbon-ti catback
MRT downpipe
Catless OEM Uppipe
UTEC
NGK spark plugs (one range colder)
Greddy 60mm EGT gauge
DBA Gold Cross Drilled/Slotted Rotors
Wilwood/Perrin 4 pots
Ricey Mods:
18" Rota Subzeros GOLD w/ nitto nt555 tires
Tanabe lowering springs
STi hood scoop
Clear Corners
Debadged rear
Window Tint 5%
STi Shifter Trim
STi key
-mike
mike@roadfly.com
MJU1983 is offline   Reply With Quote
Old 09-26-2002, 10:36 PM   #40
imprezence
Send a message via AIM to imprezence
mods
Suspension/Brakes/Drivetrain
Yokohama AVS Intermediate 225/50/16 tires
Cusco Rear Adjustable Sway Bar set at 22mm
Kartboy Endlinks
Axxis Metalmaster Pads Front and Rear
Goodridge Stainless Lines
Motul Fluid
Kartboy Short Shifter
Kartboy Tranny Bushings
STi group N tranny mount
Engine
Bosal downpipe
Vishnu uppipe
Stromung 3rd cat eliminator
Apex'i GT-Spec Catback
Samco Throttle Body Hose
TurboXS TMIC Version 1
Go Fast Bits Crank and Alternator Pulley
Blitz SUS intake
NGK colder spark plugs
STi group N engine mounts
ECUTek
Exterior
STi hood scoop
STi carbon fiber replica sidemarkers
STi replica Mesh Fog Covers
STi replica V5 Spoiler
STi replica genome grill side pieces
Tinted all around
Debadged "Subaru" and "Impreza WRX"
Color Matched Grill
Color Matched Bumper Beam Cover and Fog Surrounds
DRL removal
Interior
HKS Type 1 Turbo Timer
Autometer Boost Gauge
Autometer Pyrometer (EGT) Gauge
Kartboy Shift Knob
Whistler Radar Detector
3rd Brake Light Removal with CCB cover
Miscellaneous
Weight Removal (Jack, spare, trunk carpet, etc)
Painted Fuse Box Cover, custom turbo heat shield
Hella Compact Trumpet Supertones
Quantum Racing Radiator Splitter
~Evan
imprezence is offline   Reply With Quote
Old 09-27-2002, 12:19 PM   #41
SoLo OnE
SoLo OnE's Avatar
mods
Exterior Mods:
OEM Front UnderSpoiler Kit (imported from UK)
Painted Sideskirts
JDM Sidemarkers (custom drilled holes)
STi Carbon Fiber Sidemarkers
STi Hood Scoop (painted black)
20% Llumar tint (back 3 windows)
JDM STi Projector Headlights
OEM Headlight Covers
OEM Stock Wing
STi Version 7 grille
STi Rear Badging (imported from Japan)
STi Side Door Decals (imported from Japan)
STi Version 7 Rims (imported from UK)
Bridgestone Potenza RE040 Tires
Painted Calipers
Interior Mods:
STi Version 7 Front and Rear Seats
Custom Installed STi Door Panels
JDM Ebrake Handle
JDM Shift Knob
STi Shifter Trim
STi Door Sills
Performance Mods:
Omori Column Mounted Boost Gauge
STi Uppipe (imported from UK)
STi Turboback Exhaust
K&N Panel Filter
Eibach Springs
DBA Slotted Front Rotors
Axxis MetalMaster Deluxe Brake Pads (front and rear)
__________________
>> > level-03.com
djforums.com
SoLo OnE is offline   Reply With Quote
Old 10-12-2002, 11:02 PM   #42
Got Boost
Send a message via AIM to Got Boost Send a message via Yahoo to Got Boost
ok here is my list:
Blue 5MT with no options
5zigen catback
scooby uppipe
scooby downpipe
link ems
dms 40 coilovers
cusco rear sway
blitz boost gauge
blitz oil pressure gauge
greddy egt
17" gold subzeros
STI mesh fog cover
STI shift trim
STI replica carbon sidemarkers
ver5 replica spoiler
prodrive shift knob
leather shift boot
HKS old school turbo timer
Eclipse head unit
Eclipse titanium sub
MB 6.5" in the front
ppi amps
kartboy short shifter with bushings
whiteline rear endlinks
whiteline diff bushings
boost monkey
Got Boost is offline   Reply With Quote
Old 10-14-2002, 08:52 PM   #43
silverscooby
silverscooby's Avatar
Send a message via AIM to silverscooby
Here goes:
ENGINE
Type: Turbocharged and intercooled flat ( boxer ) four, aluminum blocks and heads.
Internal Modifications: Cobb Stage 2 shortblock (2.2L)
External Modifications: VF22 turbocharger, STi 565cc fuel injectors, Walbro 255 fuel pump, MRT fuel rails, SX fuel pressure regulator, Blitz dual drive blow off valve, Vishnu 321 Up-Pipe, Vishnu power pulley, BPM GT 3” turbo-back exhaust, TurboXS top mount intercooler, MRT intercooler water sprayer.
Engine Management Modifications: TurboXS UTEC
DRIVETRAIN
Layout: Longitudinal front engine, all-wheel drive
Drivetrain Modifications: Excedy hyper-single clutch, Fidanza flywheel, STi motor and transmission mounts, STi short shifter, Kartboy shifter bushings.
SUSPENSION / BRAKES / WHEELS
Front: Konig Verdict 17x7.5 wheels, 235/40/ZR-17 Nitto NT555 tires, Prodrive sport springs, Whiteline 22mm sway bar, EBC slotted and cross-drilled rotors, EBC pads
Rear: Konig Verdict 17x7.5 wheels, 235/40/ZR-17 Nitto NT555 tires, Prodrive sport springs, Whiteline 22-24mm sway bar, Whiteline heavy duty sway bar links, EBC slotted and cross-drilled rotors, EBC pads
__________________
2002 WRX 352whp & 341ft-lbs *SOLD*
12.5@109
2004 SRT4 449whp & 457ft-lbs
11.6@125
silverscooby is offline   Reply With Quote
Old 10-21-2002, 03:52 PM   #44
djrez4
djrez4's Avatar
2002 World Rally Blue WRX wagon
.:Factory Options:.
-Factory boost gauge
-Subaru short shift
-Premium sound upgrade
-Air filtration w00t!
.:Footwork:.
-H&R Sport springs
-Cusco 22mm adjustable rear sway
-Cusco 21mm front sway
-Whiteline steel rear endlinks
-Whiteline rear strut-tower brace - STOLEN
-Whiteline steering rack bushings
-Subaru 22b 4-pot front brakes
-DBA slotted front rotors
-Goodridge stainless brake lines
-Winter wheels:
17"x7.5" Rota Tarmac in steel grey
225/45/17 Continental ContiExtremeContacts
-Summer wheels
17"x7.5" Volk Racing TE37 in bronze - STOLEN
225/45/17 Kumho Ecsta Supra 712
.:Power:.
-Deadbolt TD05H-Super16G
-Modified stock injectors
-ECUtek reflash by Tarmac-USA
-Worx Tuning blow-off valve - STOLEN
-APS 3" dual-tip turbo-back w/ high-flow cat
-Perrin Performance catless uppipe
-Ported/polished stock exhaust manifold, Polydyn ceramic coated
-Perrin Performance turbo inlet pipe
-Hyperflow TMIC - STOLEN
-GTSpec IC splitter, modified - STOLEN
-UberWagon-designed radiator shroud - STOLEN
-Greddy sandwich adaptor with oil temp and pressure senders
-Fumoto valve
-Intake silencer removed
.:Exterior:.
-Genuine STi V2 grill
-Genuine STi hoodscoop
-Prodrive UK300 headlamps - STOLEN
-SubySkids custom 1/8" aluminum skidplate
-Carbon fiber side markers - STOLEN
-Mesh foglight covers
-Removed "S U B A R U", Impreza, and dealership badge (Damn you Shortline!)
-Removed factory roof rails
-35% tint all around
.:Interior:.
-Momo Air Leather shift knob
-Pyrotect 3-point harness - STOLEN
-My Shamalan grapefruit air freshener
.:Electronic:.
-Omori 60mm WRX look gauges - oil Temp, oil Pressure, EGT - STOLEN
-HKS type0 turbo timer - STOLEN
-DRL module removed
-Foglights rewired to light independant of low beams
-Hardwired Bel Vector 985 (paid for itself 3 times over and counting!) - STOLEN
-Infinity Reference 612i 6.5" two-way speakers (front doors)
__________________
Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
The D. J. Marcus Law Firm LLC
djrez4 is offline   Reply With Quote
Old 10-26-2002, 08:02 AM   #45
MisterX
MisterX's Avatar
MY 02 WRB Wagon
Brakes and suspension
Subaru Four Pot Calipers (front)
DBA 5010 Series Two Piece Rotors (front)
H6 Rotor Conversion (rear)
Axxis Ultimate Brake Pads (front)
Brakeman Brake Pads (rear)
Goodridge Braided Steel Brake Lines
MRT Master Cylinder Brace
Noltec Camber/ Caster Plates (front)
Whiteline Swaybar End Links (front and rear)
Whiteline Adjustable Swaybar (rear)
Whiteline 23 mm Swaybar (front)
Whiteline Lowering Springs
Whiteline Heavy Duty Swaybar Mounting Brackets (rear)
Whiteline Rear Strut Tower Brace
Whiteline Anti Lift Kit
Cusco Version II Lower Arm Bar
Koni Adjustable Sport Strut Inserts
Rota Attack Wheels - 17" X 7.5" Toyo Proxes 4 Tires (winter)
SSR Comp Wheels - 17" X 75." Toyo Proxes T1-S Tires (summer)
Drivetrain
Kartboy Shift Bushings
STi Short Throw Shifter
Exedy Clutch
Exedy Lightened Flywheel
STi RA Spec Gears
STi Motor Mounts
Power
Axis Power Stage 4 engine with forged internals and Sti cams
APS DR 500 FMIC
APS TGV Delete
GPMoto equal length, thermally coated headers
TurboXs turbo-back with thermally coated downpipe
Prodrive / Scorpion Muffler
AVO 450 Turbo
Perrin turbo Inlet Hose
Perrin Big Maf Intake
Walbro 255 lph Fuel Pump
850 CC Injectors
Crucial Racing Systems Fuel Rails
Blitz SBC-ID
Speedmonkee Grounding Kit
Speedmonkee Radiator
Speedmonkee Radiator Shroud
Crucial Racing Systems 160 degree Thermostat
Crucial Racing Systems 1.4 bar Radiator Cap
TurboXS UTEC
OBX Silicone Radiator Hoses
Interior
VDO Gauges (oil pressure, temp, boost, and EGT)
Defi Pauge Pod
VDO Boost Gauge Pod
Momo Shift Knob
Exterior
WRX Badge removal
Tinted Windows
Morette Headlamps
Roof Rails removed
X
__________________
You can get there from here. WRXFanatics.com
MisterX is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
