ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Community - Meet other Enthusiasts > Everyday Impreza Talk
Everyday Impreza Talk If it doesn't quite fit in any other forum, but it's related to the club in someway, discuss it here. General suggestions, questions, and comments welcome.
Advertise On ClubWRX
Reply
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 4.29 average. Display Modes
Old 08-31-2005, 10:03 PM   #271 (permalink)
iMP|2EZiONS's Avatar
Send a message via AIM to iMP|2EZiONS
2002 WRB WRX
Exterior:
EDM STi Headlights
JDM STi Hood Scoop
JDM STi Grill
JDM Side Strake Kit
JDM Rain Visors
Painted OEM Side Skirts
OEM Rear Lip
OEM Front Lip
Ureshi Industries Window Spoiler
Seibon Carbon Fiber Trunk
25% Tint
Suspension:
Gold 18" Rota Subzero's
Nitto Neo Gens 225/40ZR-18
Eibach Pro-Kit
Exhaust/Intake
TXS UTEC
Blitz SUS Intake
Blitz Nür Spec Axel Back
Invidia Up pipe
Invidia Bellmouth Down pipe
Interior
Carbon Fiber Defi Meter Hood
Blitz BLM Oil Temperature Gauge
Blitz BLM Boost Gauge
Blitz BLM EGT Gauge
Custom Painted Interior Trim
Worx Ergo Shift Knob
Alpine CDA-9855
Infinity Reference Fronts
Eclipse Rears
White LED Dome Lights
Misc.
PIAA Ion Crystal Fog Light Bulbs
Kartboy Short Shifter
Kartboy Bushings
__________________
2005 CGM STi
iMP|2EZiONS is offline   Reply With Quote
Old 09-04-2005, 10:40 AM   #272 (permalink)
wkw
wkw's Avatar
Send a message via AIM to wkw Send a message via MSN to wkw Send a message via Yahoo to wkw
2002 PSM wrx wagon 5mt
purchased February 2002 for $500 over invoice
Engine/Power:
IHI VF39 turbocharger
TurboXS down/mid pipes
Prodrive oval tip muffler
Kartboy exhaust hangers
Vishnu Uppipe
Perrin FMIC
AVO inlet
Perrin intake
Perrin fuel rail
STi Pink injectors
Walbro fuel pump
Ecutek reflash by Tim Bailey and PDXtuning --> dynographs
PWR radiator with Perrin coolant hoses
Crucial Racing thermostat and radiator cap
Perrin catch can
Vishnu battery tie-down
Grounding kit
STi Group N motor mounts
Suspension/Wheels:
Koni inserts
Prodrive springs
Group N tops
Perrin rear swaybar with mounts and endlinks
Whiteline front sway and endlinks
Whiteline ALK
SuperPro polyurethane lateral link and trailing arm bushings
Cusco aluminum rear strut bar
Rota Torques with some sort of lightweight lug nuts
Pirelli P Zero Nero 225/45/17
Brakes:
Stoptech BBK with SS lines up front
SS lines and upgraded pads in the rear
Tranny:
Version 5/6 STi RA gearset
STi 12lb. flywheel
Exedy stage 1 organic clutch
STi short shifter
Kartboy shifter bushings
STi Group N tranny, rear diff and pitch stop mounts
Interior:
WRC shift knob
Blitz TT and boost gauge
Omori 60mm gauges - EGT, oil & water temp, fuel press and boost
Defi center gauge pod with painted dash color and silver
speedo/tach shroud painted silver
Perrin steering column gauge pod
Forester XT single din cubby with nice spring loaded door
35% tint
Audio:
newer Alpine single din deck
newer version Ai-Net iPod and XM modules
Phoenix Gold 4 channel amp for fronts and sub
old school Soundstream 2 channel amp for rears
Boston Pro speakers up front
Boston Rally speakers rear
Boston G2 10" sub in .5 cu/ft enclosure that is bungie'd to my rear strut bar
lots and lots of dynamat
little mods:
fog light mod (fogs are gone now, thanks a bunch Perrin FMIC!!!)
DRL disabled (unplugged the pass side dash module)
switch for omori gauge lighting
switch for driver's side radiator fan
pending mods:
I plan on upgrading the steering rack someday
2.5L of some sort someday when my stock 2L blows up
I know my mods aren't anything too special but my car hauls ass and handles like a go-kart!
wkw is offline   Reply With Quote
Old 09-04-2005, 12:41 PM   #273 (permalink)
Counterculture Moderator
04.SPT.WRX's Avatar
Copied, pasted and expanded from my profile listing.
2004 Impreza WRX Sedan in Platinum Silver Metallic 5 speed manual transmission.
Estimated HP:
Dynapack 237 awdhp 268 awdtq (~316 hp@5200 rpm ~358 ft lbs of tq@3700 rpm in 2004 SAE flywheel numbers).
Engine/Transmission mods:
Deadbolt Monster TD04 (a stock WRX TD04 turbo ported / polished, balanced and both sides ceramic coated).
GM boost control solenoid.
Cobb AccessPORT v1.0 Protuned Stage 2 93 octane 19 psi maximum. Tuned by Agile Automotive Performance
Black Samco intercooler and throttle body hoses.
Grimm Speed Air Oil Separator.
Lathe Werks alternator shroud.
Kartboy battery tie down.
GP Moto snorkus delete elbow.
Perrin uppipe.
Perrin lightened crank pulley.
NGK Iridium BKR6EIX spark plugs.
Cobb stainless steel turbo heat shield.
Cobb turbo back exhaust with high flow catalytic converter and Cobb urethane exhaust hangers.
FHI 20 psi BOV.
Lathe Werks acetal copolymer teardrop WRX knob.
Kartboy short throw shifter with front / rear Kartboy bushings.
GroupN pitch rod.
GroupN transmission mount.
Kartboy crossmember bushings.
2 quarts Redline Synthetic Shockproof / ~1.7 quarts Redline 75-90W NS Synthetic in the gearbox.
Suspension/Wheel mods:
Öhlins fixed perch struts, GT Works camber plates, Racecomp Engineering yellow springs, GroupN rear top hats, aluminum control arms.
Perrin front 25mm solid front sway bar on stiff setting.
"Big Sky" custom front endlinks.
Hotchkis 25mm hollow rear sway bar with Poltec spherical bearing rear end links and Poltec collars. Rear sway bar on medium setting.
Whiteline steering rack bushings.
Rear camber bolts to adjust negative camber.
-2.0 degrees of camber / 0 toe all around, 5 degrees of caster.
Hawk HPS brake pads.
DBA Series 4000 rotors.
Russell stainless steel brake lines.
ATE Super Blue Racing DOT4 brake fluid.
15.3 pound forged 17" x 8” WedsSport TC105N with Dunlop Direzza Sport Z1 Star Spec in 225/45/17.
Interior/Exterior/Accessories:
OEM boost gauge.
S U B A R U trunk logo removed.
Narva H1 48334 Rangepower 50 (Osram Silverstar equivalent) bulbs for low beams.
Toshiba 9011 HIR-1 bulbs for high beams
04.SPT.WRX is offline   Reply With Quote
Old 09-05-2005, 08:15 AM   #274 (permalink)
sch3nk 2k4's Avatar
Send a message via AIM to sch3nk 2k4
2002 Silver WRX
TurboXS Unichip
TurboXS Turbo Back Exhaust System
TurboXS Boost Controller
TurboXS RFL Blow Off Valve
MRT Top Mount Intercooler w/ Silicone Hoses
Perin Uppipe
Injen Race Division Cold Air Intake
Greddy Turbo Timer
Optima Battery
STI Motor Mounts
NGK Iridium Spark Plugs
Exedy Stage 3 Clutch
Exedy Lightened Flywheel
Vivid Racing Stainless Steel Clutch Lines
STI Transmission Mounts
Kartboy Short Shift and Bushings
Tein Flex Coil Overs
Cusco Strut Tower Brace
MRT Front Sway Bar
MRT Rear Sway Bar
MRT Front and Rear Links
Sparco Torino Seats
Sparco 4 Point Harness (Drivers Side Is Hooked Up, The Other Is In A Bag)
Defi Gauge Pod (custome painted)
Greddy Boost Gauge
Greddy Oil Pressure Gauge
Greddy EGT Gauge
STI Titanium Shift Knob
18" Competition Wheels
Kuhmo Escta MX Tires
Stoptech Big Brake Upgrade (front, red)
Stoptech Rotors (rear, red)
Goodridge Stainless Steel Brake Lines
Prodrive UK300 Projector Headlights
STI Fog Light Grills
STI GCB Front Grill
STI Hood Scoop
Subaru 3 Piece Front Lip
Subaru Side Skirts
Subaru 3 Piece Rear Lip
STI Adjustable Rear Wing
Viper Alarm w/ Ignition Kill
Projects: Selling it and buying an Evo IX MR
sch3nk 2k4 is offline   Reply With Quote
Old 10-24-2005, 12:29 PM   #275 (permalink)
2004 Wrb Wrx
2004 WRB WRX 5mt premium package, boost gauge, short shifter
Mods:
Whiteline Steering Rack Bushings
Cobb AP Stage 1
Tein H-tech springs
KYB AGX struts
Perring rear sway and Fr/Rr endlinks
dan240 is offline   Reply With Quote
Old 10-26-2005, 05:33 PM   #276 (permalink)
2002 WRX Wagon
Exterior:
EDM STi headlights
Cheapo Gruppe-S grill insert
Interior:
Sabelt Harnesses
Homemade camera mount
Electronics:
Greddy 60MM Oil Pressure and EGT gauges
Turbosmart E-Boost2
V7 cluster
HYDRA EMS
Drivetrain:
17" Work Emotion 17x9
245/40/17 Kumho XS
Stop Tech front BBK
Carbotech XP10 front XP8 rear pads
Type RA cryo-treated gearset
STI front LSD
Redline Ultralight Shockproof Lube
Generic short shifter
ACT 6 puck unsprung clutch
ACT Streetlite flywheel
Suspension:
BC Racing coilovers with Element Tuning Custom valving
10k front/10k rear spring rates
Whiteline roll center kit
Whiteline ALK
Whiteline lateral links
Whiteline F&R sways
Whiteline endlinks
Whiteline rear strut tower brace
Carbing front strut brace
Engine:
JDM Sti V7 long block
V8 Intake manifold
Samco radiator hoses
Crucial thermostat and cap
Agency power (APS knockoff) turbo inlet
TurboXS shorty intake
Hyperflow FMIC
Tial BOV
Home ported and wrapped stock header
Ultimate Racing wrapped uppipe
Tial 38MM wastegate vta
FP Green 3" inlet
PE800 injectors
NGK BKR7E plugs
AVO oil catch can
Tuned by Scott Siegel
441 whp on 110 octane
bob-e is offline   Reply With Quote
Old 10-26-2005, 06:36 PM   #277 (permalink)
Send a message via AIM to sadkorean34
02 WRX.
Premium Package.
Exterior:
DIY sideskirt xD
Koji headlight
few ugly stickers. (ClubWRX.net, turbo>na, SHOCKERS!)
Engine:
apexi short ram intake.
Perrin single tip catback.
gutted downpipe.
CompuStar with upgraded mhz+ + remote start, turbo timer.
__________________
03' C i
sadkorean34 is offline   Reply With Quote
Old 11-06-2005, 10:30 PM   #278 (permalink)
Send a message via AIM to jpsimon
03 Sonic Yellow WRX
Engine:
samco IC hoses
vishnu catless upipe
helix catless downpipe
bosal twin tip exhaust
vishnu ecu reflash
Suspension/Wheels:
Helix DNA Coilovers
Rota SDR Bronze 17x7.5
Sumitomo HTR Z II tires
Exterior/Interior/Other:
STi EDM Headlights
STi Grille
STi c/f blinker covers
STi V8 front seats
Painted Skirts
Hardwired V1
Debadged Trunk
jpsimon is offline   Reply With Quote
Old 11-06-2005, 11:24 PM   #279 (permalink)
E-Wrex's Avatar
Send a message via AIM to E-Wrex
'05 WRB 5-speed WRX
Engine/Performance:
VF39
STi pink 565cc injectors
Walbro 255lph fuel pump
Perrin Front mount Intercooler
Perrin Intake
Perrin Up-pipe
ERZ Down-pipe
Apex'I N1 Cat-back Exhaust
TurboXS Utec
TurboXS Tuner (wideband o2 sensor/tuner)
Fake STi oil-cap (came with my ebay strut-bar so STFU! lol)
Weapon-R Coolant reservoir (managed to break the one that came with the FMIC)
Grounding kit (more ebay goodness)
Perrin adjustable short-shifter
Tuned @ PDXTuning by Mick for 255Whp@17.5 psi. I need to go to a stiffer wastegate spring to hit my goal of 20psi and hopefully close to 300whp. We shall see, can keep up with a stage 2 sti, or has in the past, and will most certainly eat a stock STi for breaky.
*Going reverse mani as soon as I can find someone capable of doing it, as well as a twin-scroll vf37 set-up if I can find a cheap way of doing it. Talk about stock turbo spool with a front mount
Suspension:
Perrin Tunersport springs
APC Front Strut bar (ebay )
STi Replica Rear strut bar (ebay )
18x8 Rota Formula mesh
Dunlop SP01 235/45/18s
*Next big project is suspension and brakes...
Exterior:
STi wing
STi splitters
STi fog-covers (to cover the empty fog light holes from the fmic of course... )
Varis CF Exhaust finisher
Blue Weapon-R "Tskuba"(or h/e you spell that isht) ricer lug nuts I got in the raffle at WCSS8
35% tints
"I-badge" in blue
Cleared headlights
Debadged "S U B A R U" from the back, and took off the pink stickers up front.
*Going for a CF Trunk lid and a CF s203 replica wing.
Interior:
Prodrive shift knob
Clarion DXZ855MP Headunit
Ipod aux-in
10" Phoenix Gold sub
Alpine V12 amp
Valentine 1 radar detector
Mad-dad clarity gauges(EGT, Boost, oil press.) in an autometer a-pillar pod.
Outdoor temp. gauge
Seats and the like will probably be accumulated over time... and maybe a roll cage :P
More to come of course, other wise I wouldn't have started in the first place...
__________________
My poor tranny!... someone sell me an aspen white 06 sti.
Mods
E-Wrex is offline   Reply With Quote
Old 11-07-2005, 06:54 AM   #280 (permalink)
the mike's Avatar
Send a message via AIM to the mike Send a message via Yahoo to the mike
Guess I should add the new WRX since I don't have the old one anymore...
2002 Aspen White WRX Sport Wagon:
TXS catless stealthback
Prodrive oval tip axleback
Perrin Uppipe
Eibach wagon sport springs
EBC slotted and dimpled rotors
EBC GreenStuff pads
Whiteline rear sway bar
Perrin rear endlinks w/Grade 8 bolts because I keep breaking the stock ones
STI BBS wheels w/ebay STi center caps
Yokohama ADVAN A046 tires(235/45/ZR17)
JDM STi projector headlights
Omori Boost and Oil Temp gauge
USDM V8 STi cluster
CGlock
StickerCity.com fog light film
Vanity plates:
__________________
Been around here for 7 years now.
the mike is offline   Reply With Quote
Old 11-14-2005, 08:48 PM   #281 (permalink)
cstruzyna 2.5rs's Avatar
Send a message via AIM to cstruzyna 2.5rs
That is probably one of the sickest things i have ever seen. So tight.
cstruzyna 2.5rs is offline   Reply With Quote
Old 12-03-2005, 09:16 AM   #282 (permalink)
rr1911's Avatar
Send a message via AIM to rr1911 Send a message via MSN to rr1911 Send a message via Yahoo to rr1911
nice
rr1911 is offline   Reply With Quote
Old 12-03-2005, 11:09 PM   #283 (permalink)
Project Night's Avatar
Send a message via AIM to Project Night
This is what I want, not have
2004 Java Black Subaru Impreza WRX (5 Speed)
HKS Carbon/Ti Exhaust
Helix Downpipe
Helix Uppipe
K&N Typhoon Intake
Carbon Fiber: Hood and Scoop, Trunk, License Plate Frames, Mirrors, Foglight Covers, Exhaust/Bumber Guard, Shift Knob, E-Brake Handle, and anything else I can think of.
HKS SSQV Blow-off Valve (I like the noise)
Black Rims (not sure which kind, or if I want black rims, maybe bronze)
Tinted windows
Rockford Fosgate 12'' Sub
No Wing (Debadged except for the "Subaru" across trunk)
That's about it, I know there's more but I can't think of it. I just got to sell my truck first.
Project Night is offline   Reply With Quote
Old 12-03-2005, 11:39 PM   #284 (permalink)
svc
I <3 Kelly Clarkson
svc's Avatar
Perrin Uppipe
EBC GreenStuff pads
USDM V8 STi cluster
CGlock
Vanity plates:
Hell yeah man! We have almost twin cars... here's me:
2003 PSM WRX Sport Wagon:
Helix Uppipe
Stoptech Stage II slotted rotors
Stoptech pads + stainless steel lines
Perin rear sway bar
Helix rear end links
Rota Tarmac II wheels with no center caps
Yokohama ES100's (my "winter" wheels right now)
Greddy Boost and Oil Temp and Oil Pressure and EGT gauges
Odyssey Outside Air Temp gauge
Clock re-wired to the headliner
Rockblocker headlight film
a few other things:
Koyo Radiator
IC sprayer
Custom sub enclosures built by me
STi v7 seats
STi Sideskirts
STi grille
Samco hoses all over
Rails removed
Other than that, I can pretty much copy paste your mod list.
__________________
sammAy!
svc is offline   Reply With Quote
Old 12-05-2005, 06:23 PM   #285 (permalink)
Joris's Avatar
2005 Aspen White WRX Sedan
Stock:
• STi Short-Throw Shifter
• MOMO Shift Knob
• MOMO Parking Brake
• Wheel Locks
• Battery Warmer
• All-Weather Floor Mats
• Cargo Tray
Aftermarket:
Power Mods:
• COBB AccessPort Stage 2 (v1.3 93 oct.)
• PDE Catless Downpipe
• Gutted OEM Uppipe
• Intake Silencer Removal
Suspension Mods:
• Falken Ziex ZE-512 225/50/16
• Hawk HPS Front Brake Pads
• STi Aluminium Lower Control Arms
Show:
• Eurolite Xenon High-Beams
• Under-Dash Neons
Wish List:
Power Mods:
• Apex’i N1 Cat-back Exhaust
• VF34/39
• STi Pink Injectors
• Walbro 255lph Fuel Pump
• Subaru Impreza WRX STi Type RA Gearset
• Protune
Suspension Mods:
• Cusco 21mm Front Anti-Sway Bar
• Cusco 20-22-24 Adjustable Rear Anti-Sway Bar
• Prodrive Springs
• KYB AGX Adjustable Shocks
• Whiteline “Comfort” Anti-Lift Kit
• Rota 17” G-Force + Rubber
• SS Brake Lines
• Hawk HPS Rear Brake Pads
Show:
• Autometer Gauges + OEM Subaru Gauge Pod
• Greddy GRacer Aero Front Lip
• Chargespeed V1 Rear Bumper
• Wingless Trunk + Mines Lip Spoiler
• VIS Racing OEM Carbon Fiber Hood
• 35% Tint
• Spaco Milano Seats
__________________
MODS
Joris is offline   Reply With Quote
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertise On ClubWRX -->
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.1.0
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
You Rated this Thread:
