The official WRX VS The Curb thread - Page 5
Page 5 of 24 FirstFirst 123456789101112131415 ... LastLast
Results 61 to 75 of 358
This is a discussion on The official WRX VS The Curb thread within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Originally posted by Stumbo Nothing wrong with having a tire shaved... ditto...
  1. #61
    Jul 2001
    Plains of Eastern Montana
    ditto
  3. #62
    Registered User archiebrown's Avatar
    Mar 2004
    Melbourne Australia
    Belted a curb, now I wobble
    Hey Hey,
    I hit a curb last night and whacked my front left wheel at about a 30 degree angle doing 20kmh. There is no obvious damage/buckling to the rim and no obvious tyre bulge. There is now a minor wobble coming through the steering wheel, and I am wondering if I have just knocked the camber out, knocked the wheel out of balance or done something a bit more serious. I have whiteline suspension and sways with stock rims and Potenza tyres.
    Any thoughts? - as I dont want a suspension shop to drill me for big dollars by replacing my entire front setup.
  4. #63
    Mar 2002
    Chicago
    control arms and bushings
    u might have messed bent the control arms and if u did i got some new sti control arms that im selling for
  6. #64
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    I'd say to get an alignment done, drive around for a while and see if it comes back and possibly go back and make sure that the alignment is still where you set it after a week or two. Then depending on those results you can either assume it's just the alignment that was off or if it was the control arm, tie rods, etc.
    I can assure you (from personal experience) that you can mess a lot of things up with a curb and even with those speeds you could have bent some pricey parts.
    autobahn storming scooby
  7. #65
    Registered User verbal's Avatar
    Oct 2002
    I dunno, I just don't think I trust it. It doesn't sound like a good thing to me. I just picture a cheese slicer being taken to a brand new tire.
    Do they have machines that do it or what?
  8. #66
    Jul 2001
    Shaving of competitive has been done for a long time. Yes it's a machine that does it. Here's a good article from tire rack- talks about tire shaving and awd systems.
    Boils down to either buying one shave tire- matching your others or buying four new ones at full tread- you have to do the math. Much depends on the current wear and condition of your tires.
    http://www.tirerack.com/tires/tirete...chingtires.jsp
    Big Sky
  9. #67
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    you should theoretically be able to just match the front pair and rear pair as long as they aren't TOO far off (couple K miles)
    i would say replace the set anyway at 15K
    dR
  10. #68
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    I think Subaru says they must be within 3/32"? Does that sound right?
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
  11. #69
    Jul 2001
    2/32nd of each other in treadwear- so yes that is correct.
    How many miles on the tires?
    Big Sky
  12. #70
    Mar 2004
    Melbourne Australia
    Thanks gents.
    Just had an alignment done, which came back to say that I knocked the wheel in question out by 3 degrees, and that it is also buckled some. After a rotation and balance all is ok, except now I want to spend 2000 bucks on the racing rims and Eagle F1 tyres I saw while I was there.
  13. #71
    Jul 2001
    Originally posted by archiebrown
    Thanks gents.
    I don't understand what your saying you knocked it out three degrees- three degrees of what. Generaly speaking if your 3 degrees of caster or camber out, balancing your tires won't do it.
    Do you have your before/after alignment #'s- I'd be able to tell a lot more w/ the #'s.
    Big Sky
  14. #72
    Mar 2004
    Melbourne Australia
    Here's some numbers:
  15. #73
    Jul 2001
    Your rear toe was way out of wack- good thing you went in for an alignment. Your front was a little out, but not nearly as bad as your rear.
    Your caster # is right where it should be and your camber #'s are right at spec as well.
    I always get nervous when someone hits a curb as it can do a fair amount of suspension damage. You look like your in good shape.
    Big Sky
  16. #74
    Oct 2002
    Big Sky
    I put them on at 19k spring of 2003. Took them off for winter, so I'm not sure how many miles are on them. Just put them back on a month ago and I'm at 40k now. So I'd say at LEAST 15k is on them.
    I've never gotten an alignment since I bought the car and I'm kinda anal when it comes to certain things. I'm not sure if they're wearing evenly. The Toyo T1S Proxes are a little loud to me lately, so I'm considering buying a whole new set. Hopefully I can find something that gives the same performance and treadwear but less noise. *shrug*
    I need coilovers first anyway.
  17. #75
    Registered User superic's Avatar
    Jun 2004
    Western NY
    STi rims + concrete curb = :-(
    One of my rims got a bite taken out of it by a curb last night. It's all scraped up (pretty badly) now. Any tips or tricks on how to smooth it out or fix the coating to prevent corrosion? I guess these are going to be my winter rims now...
    (BTW I only parked close to the curb so no one would hit me, someone else moved my car and hit the wheel!)
    Black 2005 STi
    Mods: iPod resting in console and turbo gauge
