Pulled the motor in old yellow......
Page 1 of 7 1234567 LastLast
Results 1 to 15 of 96
This is a discussion on Pulled the motor in old yellow...... within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; I bought a heavily modified WRX out of AZ in Feb. Drove down and towed it home. Here are some ...
    Registered User MJU1983's Avatar
    Dec 2001
    Saint Louis, MO
    I bought a heavily modified WRX out of AZ in Feb. Drove down and towed it home. Here are some pictures of the project. The old engine had a timing belt slip off and it bent some intake valves. I figured if I am going to pull the motor, why not replace with something a little beefier?
    Car:
    My friend JJ:
    Here is what it looks like all clean/ running:
    Pulling the old engine:
    It's apart, only has bent intake valves:
    AND NOW THE NEW!!
    It took me several months to get it squared away (mostly due to my laziness), but the shortblock done now.
    - 2.2 Liter Turbo Legacy case, bored/sleeved
    - Darton ductile iron sleeves
    - US STi forged crank, balanced/polished/drilled for better oiling
    - Pauter Forged connecting rods
    - Ross forged pistons, moly coated skirts, swaintech gold coated tops
    - ACL race series bearings for mains and rods
    - ARP oversized head studs
    Pictures:
    I painted my covers:
    Modifications.
    Engine, go fast mods, and misc:
    2.2 Turbo legacy shortblock (fully closed deck), bored /sleeved - 2.4 Liter final displacement
    Darton Ductile Iron Sleeves
    USDM 2.5 STi forged crank, balanced/polished/drilled for better oiling
    Pauter Forged Connecting Rods
    ROSS Forged pistons, coated skirts, swaintech coated piston tops
    ACL Race series main and rod bearings
    Oversized ARP head studs
    Version 8 JDM STi big port heads
    Subaru 12mm Oil Pump from New Zealand
    APS DR725 bar/plate FMIC
    13 row bar and plate oil cooler
    Fujitsobo Power Getter exhaust
    Tial 38mm external wastegate setup
    Tial BOV
    Ported Ceramic coated Up ppipe
    Ported Ceramic coated manifolds
    Ported throttle body
    AVO450 turbo
    PE650 injectors
    Walbro pump
    Greddy catch can
    APS Intake
    Ecu-Tek
    UTEC
    JDM STi Version 8 ECU/AVCS working
    PWR radiator
    Perrin Turbo inlet hose
    JDM STi Radiator Cap
    Samco Coolant Hoses
    Samco Radiator Hoses
    AVC-R boost controller
    Defi Pod
    Greddy Oil Temp guage
    Greddy Oil Boost guage
    Greddy Oil EGT guage
    Grounding kit
    Knock link/w buzzer
    Optima red top Battery
    Suspension/Drivetrain:
    Tein Flex coilovers
    MRT rear adjustable camber plates
    WhileLine ALK
    Whiteline sub frame locks
    Perrin rear sway bar
    MRT solid end links
    Cusco Type II under brace
    Cusco front strut bar
    Cusco rear strut bar
    Cusco rear V-brace
    STi GrN motor mounts
    STi GrN tranny mounts
    JDM STi Sub frame assembly
    JDM STi lateral links
    JDM STi end links
    Steering rack bushings
    JDM STi 6 Speed Transmission w/Surtrac
    JDM STi R180 rear differential
    JDM STi axles
    JDM STi hubs/pbrake
    JDM STi drive shaft
    Kartboy Short Throw Shifter
    Kartboy Front/Rear shifter bushings
    Exedy 13# flywheel
    Exedy clutch (or) STi/Cusco twin plate 6 puck (or) STi kevlar 6 speed clutch (or) ACT 6 puck race clutch
    Brakes:
    Brembo Gran Turismo Front Calipers w/ 2 piece floating hat rotors
    Brembo Rear brakes
    Gas Slotted rear brake disks
    SS Brake lines all around
    MRT master brake cylinder brace
    Looks (exterior):
    Fully repainted by Lotus of Scottsdale
    JDM STi projector headlamps
    18" Silver OZ Super Leggera Wheels
    Trial front lip
    Shaved A Pillar antenna
    Rear roof SharkII antenna
    Custom OEM Front bumper work
    JDM Aero Guards
    JDM STi Grill
    STi CF side markers
    STi fog mesh covers
    OEM rear under spoiler
    Kaminari CF Hood/Painted
    CF Rear Wing
    Sparco Hood Pins
    Looks (interior):
    JDM S202 BLUE speedo/ cluster
    JDM STi steering wheel
    JDM STi parking brake
    JDM STi shift knob
    JDM STi center console/w trim ring & boot
    JDM STi sub visors
    JDM STi door cards
    STi rear seat
    Sparco Torino front seats
    Subaru OEM CF interior trim
    Bumps in da trunk:
    JL Audio 10W3v2
    Custom in wheel well sub Enclosure
    Eclipse deck
    Entire interior floor and trunk coated with Dynamat
    Registered User tayhadar1's Avatar
    Apr 2006
    Spokane, WA
    Nice
    2004 WRX Sti Cobb Stage 2
    GO COUGS!!!
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    How long did that take to do?
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Dec 2001
    Saint Louis, MO
    Quote Originally Posted by bcyb1029 View Post
    About 3 hours...should have gone a lot quicker, but the up pipe/ external waste gate/ down pipe setup was designed horribly.
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Wow cool man, nice job.
    Lead Wrench @ WTF Tuning, LLC
    Registered User pweizman's Avatar
    'Nati, Ohio
    What happend to it?
    Won't run?
    Patrick
    RSX-S
    Sold: '03 WRX Wagon (bugeyes rock!)
    Registered User bkotzman00's Avatar
    Apr 2006
    York, PA
    Quote Originally Posted by pweizman View Post
    What happend to it?
    Won't run?
    Patrick
    he bought it with the blow motor, there is a thread about it on here somewhere
    04 WRX Java Black
    Mustang Dyno 218 awhp 216 awtq
    1978 Honda CB400Tll
    yea you know its modified
    1974 Honda CB750 Bobber
    still in the works
    Dec 2001
    Saint Louis, MO
    Quote Originally Posted by bkotzman00 View Post
    Correct......... found a DEAL on NASIOC and bought it.
    Timing belt slipped off and he blew the motor. Maybe just bent valves (hoping), but we shall see.
    Apr 2006
    York, PA
    Quote Originally Posted by MJU1983 View Post
    if that is all it is that would be great, yea I saw the mod list for this car and when you fix her up she will be a beast
    are you keeping the front lip? in the after pics it was removed
    04 WRX Java Black
    1978 Honda CB400Tll
    still in the works
    Registered User PJO42387's Avatar
    May 2006
    DF-DUB
    When you get done i wanna see some videos
    If you want to get rid of that wing pm me
    CGM
    Dec 2001
    Saint Louis, MO
    Yes, I am keeping the front lip. It was cracked by the tow truck driver who picked up the previous owner after failure.
    Feb 2006
    Chicago
    I remember seeing that car on nasioc, that thing is sweet.
    Dec 2001
    Saint Louis, MO
    Yep, it's Erics old car (ebeck).
    Thanks.
    Registered User lovetheboost121's Avatar
    Nov 2006
    Douglas, AZ
    what are the mods on it
    Die Trying, Not Watching!!
    2002 Subaru wrx stage 2
    2000 Kawasaki KX250
    2004 Honda CRF450
    Dec 2001
    Saint Louis, MO
    Quote Originally Posted by lovetheboost121 View Post
    APS DR725 FMIC
    Tial 38mm wastegate setup
    Tial BOV
    Blacked out lights
    Tein Flex coilovers
    MRT rear adj. camber plates
    WhileLine ALK
    MRT solid end links
    Cusco rear V-brace
    Brembo 2 piece, floaing hat, Jaguar caliper GT front brakes(35 pounds lighter than STI brembors)
    Brembo Rear brakes
    JDM S202 BLUE Ver7 cluster
    JDM STi shift knob
    JDM STi sub visors
    JDM STi door cards
    JDM STi Scoop
    STi rear seat
    Defi Pod
    JL Audio 10W3v2
    Eclipse deck
    JDM STi end links
    JDM STi Surtrac R180
    JDM STi axles
    JDM STi hubs/pbrake
    JDM STi drive shaft
    JDM STi 6 Speed w/Surtrac
    JDM HKS Turbo timer
    AVO450 turbo
    Knock link/w buzzer
    PE650 injectors
    Walbro pump
    Greddy catch can
    APS CAI
    Optima Battery
    Ecu-Tek
    PWR radiator
    Samco Coolant Hoses
    Exedy 13# flywheel
    Exedy clutch
    Grounding kit
    Trial front lip
    JDM Aero Guards
    JDM STi Grill
    STi CF side markers
    STi fog mesh covers
    CF Rear Wing
    Sparco Hood Pins
