sounds like you need to release the clutch with a lil slower motion on your UPSHIFTS with either no gas or jus a lil bit that will match the revs in your next higher gears.. Alot of this depends on how long it takes you to do your upshift, and how far the revs drop in between. Keep in mind you don't want to rush the shifter and the syncros...esp in our cars... Thats one of the keys to longevity..
Rev matching on downshift would jus be the "blip" of throttle that will raise the revs to matching the RPMs of your next LOWER gear with a normal single clutch. Double clutching is the same except letting the clutch out on your way thru nutreal while you do the blip, basically treating nutreal as as a seperate gear....
I've been driving manual street cars for over 25 years, racing manual (of course) motorcycles for 20, and cars for5+ years ( NOT streetracing, thats NOT racing thank you..) and have NEVER had to replace a clutch or tranny part. I usually put between 150K - 250K miles on my streeet cars B4 I retire them...So you CAN drive a REX for that long, even an 02, hard without hurting a tranny if you just know what you are doing and use alil mechanical sympathy..![]()
LinkBack URL
About LinkBacks
