2012 wrx will hardly idle after I changed my plugs
Results 1 to 4 of 4
This is a discussion on 2012 wrx will hardly idle after I changed my plugs within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Hey what's up everyone? I had an issue with my wrx it was reading cylinder 3 misfire and I thought ...
    Registered User $poolnWRX's Avatar
    Mar 2017
    Hey what's up everyone? I had an issue with my wrx it was reading cylinder 3 misfire and I thought I fouled a plug or burned up a coil pack but that was not the case. The plug came lose on cylinder 3 that's all I already had the car apart to do the plugs so I changed those as well with the same exact plugs that were already in it. One thing is the battery was out of the car for 4 days. Would I need to reinstall the e85 map since there was no battery, I had to set the clock again and the radio so I was hoping this might be the problem. When I am driving the car it runs fine just when I come to a stop it dies and if I start it and sit there it will try hard to idle and after a few seconds it will stay idleing but tent to hard to just idle
    Mar 2016
    Did you gap and torque the plug down? Is the coilpack connected correctly? And last of all, check all of your vacuum lines
    lit fam XJman's Avatar
    Feb 2015
    At work
    I think you have a bigger issue somewhere
    All? NO ALL!
    Mar 2017
    Well there was no bigger issues here, since my battery was out I had to reset the ECU and the car just had to relearn problem solved. Best to check all the small things first. Happy there is no real problems she runs great on e-85
