I have a 2016 WRX, and I'm wanting to start doing my own oil changes.
How do most people jack up the car to do this?
Do you jack up just one front side?
Do you use jack stands?
Has anyone chocked both back tires (front and back of tire), and used 2 floor jacks (one on each front side) to raise the car?
I've read some threads that said there is a front center spot to raise the entire front end, and then others that say don't do it.
I'm just trying to figure out the best and safest way to accomplish it.
Always use jack stands. I have always done it like this.
Place hand brake, and keep in 1st gear.
Jack up one side on the front, place jack stand. Jack up other side, place jack stand.
Go under car and do the oil change.
Then reverse order.
Thanks. It just freaks me out when the back wheels come off the ground. It feels like something will snap or break.
Is there anything wrong with using two jacks to raise the front end, and then use the jack stands? As long as the back wheels are both chocked that is.
Sure if you want to run back and forth pumping one up a little then the other. I'm a huge fat man and always jack mine a mile high and have one tire airborne until the other side comes up. I'm sure there is a fair amount of stress on things so I wouldn't open doors with it like that but it should be fine.
Ramps as ej mentioned are also a great idea. Just don't cheap out I've seen them collapse.
Use ramps, they aren't that expensive and most auto parts stores have them in stock. Jack and jack stands are slightly more time consuming than just driving your car up on ramps.
^^this^^
No need to build wooden "pre ramps", just cut a few 12" sections of 2x4 and put in front of the ramps to get the car up to the ramp.
I was looking at a 2 post lift for my small garage - but this option is interesting for small spaces: Ranger QuickJack BL-5000SLX Portable Lift — 110 Volt, 2 1/2-Ton Capacity, Model# BL-5000SLX 110V
I wonder if there is some sort of adaptation that could be made to make sure to hit the correct lift point for our cars? In any case, I would definitely use jack stands as a back up.
I agree that ramps would be much easier, but most of them that I've seen will not fit under the front of the car unless you build a wooden ramp to drive up on first. If someone has one's that will fit under the front of the car, please list them.
This will be my first time changing the oil on my own, so I think I will go with the two jacks and jack stands. And then leave both the stands and jacks supporting the car. That should be safe enough, I would think. And then I'll look at ramps for the future changes.
I set the parking brake, put it in 1st gear.. jack up one side with a floor jack, put a jack stand under it, jack up the other side, jack stand.. and leave the floor jack there (just a hair lower than the jack stand), and chock one rear wheel.
I have ramps, but they're a pain to dig out of my garage, not to mention heavy.. and they tend to slip forward on my driveway and scrape up the concrete. I only use the ramps if I want the whole car off the ground.
Back in college when I lived in an apartment complex (and hardly had any tools) I would pull around to the back of the parking lot, drive one side of the car up onto a curb, and drain it like that.
I use floor jack on one side (the side that will make the drain plug lower on the BRZ, as the car becomes angled), put jack stand in ahead of the jack. I ease the car down on the jack stand, and test for stability, then leave the floor jack in as a backup.
Car is in 1st, parking brake up, chocks (funky-shaped rocks from our landscaping) in front of and behind the rear wheel that's on the ground. Probably overkill, but I'm really into breathing.
I use race ramps. They are expensive, but well worth it. They will never slip or shoot out from under your wheel when you try to drive up them, like I have experienced with Rhino Ramps. When you change the oil, you want your car to be level so it all drains out, so just jacking up the front won't do.
When I am changing my oil, I just drive up the front ramps, chock the front wheels on the ramps (Probably unnecessary) Then jack up the rear by the rear diff, and lower it onto the wheel chocks, which are at the same height as the front ramps.
If I want to get it on jack stands, so I can remove the wheels, I drive up the front ramps, chock the front wheels, and jack up the rear by the diff, and lower it onto jack stands at the rear/side jack point. I then jack the front by the front jack point/skid plate area, remove the ramps and put jack stands on the front side jack points.
Most jacks won't fit under the front to reach the front center jack point.
The race ramp set will run you around $300, but is completely worth it, if you regularly do your own work/maintenance on your car. It makes it really easy to safely get your car in the air, without having to worry about jackstands, and messing up your side jack points. It always makes me nervous jacking up a car, when the other half is sitting on/balancing on jackstands, so I try to avoid it whenever possible.
Thanks whiplash. I like that setup, but I'm not sure about the $300. I may just make myself some wood ramps.
Now since you have a 2015+, do you have a shot of this infamous center jack point spot on the front? I just can't seem to find a good answer/stot online anywhere.
I use cheap steel ramps in the garage . . . they're heavy, but plenty rugged. Due to the angle of the ramps I do use a couple of short 2 x 8s. I haven't had any issues with slippage and feel quite confident while working underneath during the oil change . . . which tends to be a 15-25 minute job start to finish (digging out the tools and equipment to the end stage of picking up and recording the mileage in my maintenance book.)
I use ramps. I think Rhino Ramps... they were around $40. They fit under the front end with my summer wheels, and with winter wheels I have two pieces of plywood that I place in front of them to give me that extra needed centimeter of clearance. My car is a 2014 though, so I've got a little more clearance if i'm not mistaken. Either way, a few pieces of stacked plywood will be sufficient to get the ramps to clear your bumper.
I got a set of plastic ramps I bought for $40 from Autozone eons ago and the car gets up them just fine. Honestly though once I discovered I was only saving myself about $15 vs just taking it to the dealer, I started taking it to the dealer. Plus they check everything, top off fluids, check air pressure etc etc for you.
In the past I justified doing it myself with the thought that oil changes at the dealership were done by the most inexperienced techs. Heard horror stories about people getting the wrong oil or wrong amount put in their performance car. It usually takes me less time in my driveway than making an appt to take it to the dealer. Plus, I always enjoyed getting under the car and learning where things are. Have people here had generally good experiences with Subaru service depts doing minor maintenance stuff?
Maybe a bit of oil on my hand when I take off the oil pan bolt . . . but wouldn't have that if I wasn't so cheap and would spring for a Fumoto oil drain valve. What little is on my hand gets wiped off with a paper towel and thrown away. Old oil is drained into the empty oil jug and given to the local garage which burns it in their waste oil heater in the winter.
I suppose I could get a bit dusty from a dirty concrete floor in the garage, but if I'm really trying to stay on the clean side I'll use my mechanic's creeper or just toss down a broken down cardboard box.
The filter spins off the top so there is no oil to drip all over the place.
I really don't find changing the oil to be a dirty affair.
Well. I went with building my own wooden ramps. 1-2x12 treated (for bottom boards), and 2-2x12's untreated. And these babies are solid. No cracking and collapsing going to happen here. I can have the car 1.5 inches, 3 inches, 4.5 inches, or 6 inches off the ground with these. Yes, they are much heavier, but it's worth it to me. And the cost was about $40
L ook good. B careful going up. After the wheels hop up over that final hump the car will want to keep going right through that ledge board because you'll be goosing it so much to get over the hump.
It's all good. I have the 45 degree angles on each of the board ends to help the tires roll up easier. And the stopper at the end sticks up just over 2 inches. I'd have to goose it pretty good to get over that.
The floor jack is pricey & super heavy but in every way it helps working on the car as it pumps up real fast and also goes up to 24". Perfect when you want to get in & out with the creeper which makes a world of difference. I just lift the center jack point with a small 2x4 in between so I don't crush/damage the end of the splash guard area and it's been working fine. Eventually I'll make the 2x4 wheel stands as solid & safe solution. Can never be too safe though you know?
I have the Fumoto drain valve installed which makes draining a breeze minus the oil filter which is always tad bit messy. I'm anal only because I live in a condo so I try not to make a huge mess. And of course Pennzoil Ultra Platinum 5W-30 only.
Related Threads
Subaru WRX Forum
3.2M posts
152.7K members
Since 2001
