12K service and unusual brake wear
Results 1 to 12 of 12
This is a discussion on 12K service and unusual brake wear within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; So I brought my car 2015 WRX in for its 12K mile service and the tech mentioned that my brakes ...
    Jan 2015
    Fremont, Ca
    So I brought my car 2015 WRX in for its 12K mile service and the tech mentioned that my brakes are not wearing normally and that my fronts have 9mm left which my rears have 6mm left. He said that a 1~2mm difference can be expected, but usually the wear occurs towards the front. This makes sense as the weight is shifted forward when stopping, but what would make the rears wear down faster than the fronts? I asked the tech this and he just said, "your style of driving" is the cause, but could offer no other details. Does anyone have an idea what would cause this?
    Registered User ROFLREX's Avatar
    Oct 2014
    i will have to double check my last records. i just did oil change at 20k or so and i noticed the report said my rear pads were worn more than front. i thought it was odd too. i don't see how i my driving style (or any driving in that case) could cause the rear pads to wear more quickly. unless they started out at different thicknesses lol.
    Registered User pizza_pablo's Avatar
    Aug 2015
    If your "driving style" includes driving in reverse and breaking hard, for many miles, I guess....
    Sent from my lair.....
    Today, is the tomorrow, we worried about, yesterday.
  5. #4
    Registered User rqjoe's Avatar
    Feb 2015
    Ohio
    Parking brake?
    "Hey man there's only one thing
    And one car that will do"
    And its a WRX Subaru
  6. #5
    Aug 2015
    Quote Originally Posted by rqjoe View Post
    Parking brake?
    If the new WRX is designed like my Legacy, the parking brake is comprised of drum shoes, inside of the rotor, which shouldn't affect the disc pads.
  7. #6
    Jan 2015
    Fremont, Ca
    I don't drive with the parking brake on, so that wouldn't be the culprit. I do backup into parking spaces often, but that is slow speeds and should not be a reason for higher than normal wear, or I don't think it should be a reason. Any one else with a 2015 have similar feedback after their standard maintenance?
  8. #7
    May 2010
    Pittsburgh, PA
    If you get in your car and step on the brake pedal (without the key turned to 'on'), is the pedal rock solid?
    Are the rear rotors on the newer vehicles the same thickness as the fronts to start?
    That's an odd one, to be honest.
    2011 STi Build Log
  9. #8
    Aug 2015
    Quote Originally Posted by tmcmahon View Post
    The parking brake should not affect the thickness of the rear disc pads, as it is comprised of brake shoes positioned in the inside of the rear discs at the hub area.
    Today is the tomorrow we worried about yesterday.
  10. #9
    Jan 2015
    Fremont, Ca
    I looked at Subaru's part site and wasn't able to get the rotor thickness, so I don't know what they are brand new. As for the pedal being rock solid, it is not rock solid for the first pump, but them gets stiffer. I don't know if this means anything or not.
  11. #10
    May 2010
    Pittsburgh, PA
    The brakes are a PITA to bleed completely in these cars a lot of times - hence why I was asking about the pedal. One pump before hand is reasonable, and I doubt that is your issue.
    No idea man. Sorry.
    2011 STi Build Log
  12. #11
    Jan 2015
    Fremont, Ca
    well, I will just have to ask when I bring the car in for the next service.
  13. #12
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    That's definitely not right and something seems off here. As to what it is, I have no idea. But what I do know is that the front pads will ALWAYS wear more than the rears as they do more work. your scenario should not be happening.
    2011 WRB WRX Sedan - Q300, Invidia Catted Downpipe, Cobb RAM Intake w/Box, Tuned by Turn in Concepts
    Stink-Eye Mob #696
    Build Thread
    Facebook
    @billym14
