Recharging AC
Results 1 to 13 of 13
This is a discussion on Recharging AC within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; How do I recharge an AC on a 2003 wrx? I also have a Honda and it has two ac ...
    Jan 2015
    Recharging AC
    How do I recharge an AC on a 2003 wrx? I also have a Honda and it has two ac lines one low and one high and I use the low one to recharge it. How do I do it? Also how much would I need?
    I don't think that's the right approach. If you need to add refrigerant, you have a leak. Therefore, find and fix the leak first.
    - Al Stewart
    lit fam XJman's Avatar
    Feb 2015
    At work
    Are you sure it's low? Did you have it tested? As sd said if its low you have a leak and you'll just be recharging again in a short time.
    As far as what one to charge from, I'm not sure I've never done it myself as I don't mess with refrigerant. I'd venture to guess the low side, as I would think the high pressure side would blow up the can. If my memory serves me correctly from my schooling days the fittings are different to prevent hooking up to the wrong fitting.
  5. #4
    The best thing to do is to post your high-low pressures and try to figure out what's actually wrong with the system. If you post pressures we can try to help.
    - Al Stewart
  6. #5
    Jan 2015
    Well the ac works fine the air is semi cold but not hot like as if it was broken. I just want it extra cold. I only see the high line with the H not the low line :/
  7. #6
    Quote Originally Posted by msconnie2009 View Post
    I suggest troubleshooting by making sure the cabin filter is clean, then checking actual pressures. Do you have a gauge setup, or can you rent one?
    - Al Stewart
  8. #7
    Feb 2015
    At work
    Have you cleaned the condenser, changed the cabin filter, and made sure the compressor is staying on when its supposed to be?
  9. #8
    Oct 2011
    Santa Ana, CA
    Dont just fill up. Do it a the right way.
    Check the pressure on both high and low. Put a vacuum in the system and check for leaks. Replace parts if needed.
    THEN add refrigerant to the low side. Amount needed is on a sticker on the condenser.
  10. #9
    Jan 2015
    I got a kit so I'll check the pressure when I get the gauge in the mail. Thanks guys!
  11. #10
    OK great.
    For the 2,0L cars the low side pressure should be between 127 and 196 kPa while the high side pressure should be between 1471 and 1667 kPa, at 30 to 35C ambient temperature.
    - Al Stewart
  12. #11
    Jun 2015
ID:	205753Click image for larger version.
    This is where the low side service port is on my 02' WRX. If you are going to try and charge it that is where it should be done from. Really a/c systems should be service with a machine like I use at work everyday. They are very expensive but it the only way to know how much freon was in the system and how much you are putting in. The system can be damage if there is too little or too much freon. If you have any other question I will do my best to answer them.
  13. #12
    Jan 2015
    Thanks guys. I got the car checked and it didn't have a leak so the mechanic just added some cause for some reason the gauge I have wouldn't stay it came coming off the hose.
  14. #13
    Feb 2015
    At work
    Odd, I wonder if it had ac work before and wasn't charged properly
