Turbo Lag
Results 1 to 9 of 9
This is a discussion on Turbo Lag within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Any insight on turbo lag and available mod's which can help address this? Thanks...
    Aug 2013
    austin texas
    Turbo Lag
    Thanks
    Bill Freakin Murray TownLine500's Avatar
    Oct 2013
    Boston
    We will need more info.
    What year is your car?
    WRX or STI?
    What are your current mods?
    Is your car tuned?
    Do you have an Acess Port or a Tatricx cable?
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Aug 2012
    Tucson, AZ
    You can get a supercharger
    You're always going to have turbo lag..thats just how it is
    A smaller turbo will reduce lag but also power
    Stinkeye member 520
  5. #4
    zax
    zax is offline
    \_(ツ)_/ zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Not to sound condescending, but:
    ***How to Ask a Technical Question!**
    I made this thread to help members not familiar with cars or "mechanically challenged" present their automotive dilemma in a clear and concise manner. By doing so it greatly increases the odds of diagnosing the problem more efficiently and keeps the more experienced residents here from just flat out ignoring your posts or doing the back and forth banter dance of having to extract information from you (aka: "pulling teeth"). If it requires work just to get to explain your problem ,how much work is it going to require to help you actually fix it? See where I'm going? Help us help you. It's all in the details peeps!
    Provide as much info as you can in you posts
    *All performance mods (80-90% of the problems are due to improper modding/mods)
    *octane of gasoline being used
    *Year/model of vehicle/miles on vehicle
    *When the problem started (when I changed a part vs out of the blue)
    *If you have tried to fix the problem list what you have done
    *If you have the ability to datalog definately run a log.
    If your car has a CEL(check engine light) that means you have a DTC (diagnostic trouble code).
    Before we can even help you get the code read. It makes no sense to ask why you have a CEL or to post that you have one and not post what the code is. We cannot read the code for you,so get it read. Most Autozones will do it for free. FYI- if you get the code read 95% of the time you can find how to fix the problem by merely searching by using the code number. Also the F.A.Q.'s /Stickies will contain general information about mods that cause CEL/DTC and some of the fixes.
    Use complete sentences and grammar!
    If we can't understand what your even saying or think your speaking a different language when your not, how fast do you think you problem is going to be solved? Please re-read what you have wrote. If it doesn't make sense to you it most definitely won't make sense to us!
    Be specific with your question!
    "My car is acting up,whats wrong?" Uhhhh.....okay.
    There are a TON of people on here that are very knowledgeable on these particular cars and all their little quirks. The more data and details you can provide using the correct (or close ) terminology the better the "picture" will be painted. So please use these guidelines to help us help you!
    Really, you just haven't provided enough information for us to help you!
    Zax's utterly unimaginably stock 2015 STi build thread
    Zax's Shaggin' Wagon Build Thread Now tuned for 99% pure Unicorn Jizz!
    Rollin' with the Bugeye Mafia #302 | N.E.R.D. Subject Zero
    Facebook me here
  6. #5
    Aug 2013
    austin texas
    My car is a base 5 door 2013 WRX with no mods or tunes. Thanks
  7. #6
    OMG WTF MainFrame's Avatar
    Texas, United States
    A tune will vastly improve off boost power delivery, and in turn reduce perceived lag.
  8. #7
    Aug 2013
    austin texas
    Understood. Patience appreciated. Thanks
  9. #8
    Replacing the downpipe, intake, and boost control solenoid prior to the tune would make it that much better. Still, you're not going to see a huge difference in the time it takes the turbo to hit full boost (lag), but with more power across the board, including the area prior to the turbo spooling up, the perception of lag won't be as bad as it is stock.
  10. #9
    zax
    zax is offline
    Nov 2008
    Keep in mind there are two commonly confused terms:
    1. Turbo lag - the time taken for the turbo to fully spool after full load is applied.
    2. Boost threshold - the RPM at which the turbo applies maximum boost pressure.
    Which of the two offends you most?
    Facebook me here
