WRX Coolant Sensor
Results 1 to 7 of 7
This is a discussion on WRX Coolant Sensor within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Hi Everyone, I replaced the coolant temp sensor on my 2003 wrx. the codes that were showing were a 420 ...
    Mar 2013
    WRX Coolant Sensor
    Hi Everyone,
    I replaced the coolant temp sensor on my 2003 wrx. the codes that were showing were a 420 and a 117 code. i decided to take on the sensor first since i had the cads replaced (not stock...my mistake). so i put on the coolant temp sensor and immediately noticed that the temp guage was showing Hot. i burped the system and the same thing. took it to a shop and they ran it through a coolant system diagnostic to tell me that the care was not overheating at all and that it was a false reading. does the temp sensor need to be stock? i got it from an auto parts store. it doesn't make a whole lot of sense to me.
    What are cads?
    Does the new sensor differ in impedance to the old sensor?
    Are the leads reversible or is the harness directional to prevent that?
    Mar 2013
    What are cads?
    im not sure. how could i tell?
    the harness is directional
    im sorry i meant CATS not cads.
    WRX Coolant Sensor
    If you are certain the car is NOT overheating then and only then consider seeing what happens when the harness is left disconnected. This could show whether the fault is with the sensor or the harness.
    I was also interested in any readings using a multimeter set to impedance across the old vs the new sensor.
    Mar 2013
    I will check that out. thanks for all the input.
    Mar 2013
    Quote Originally Posted by timmyflash View Post
    I spoke with the mechanic on the phone. he's telling me that it's probably something wrong with the coolant temp senor. he said all internal temps checked out normal and that it could only be between the sensor and/or the plug being the reason it's showing hot. i did not buy the sensor stock. should i have bought a stock sensor?
    I can't tell from the information given because we don't have a known good stock sensor to measure and compare to the one you've bought. I don't disagree that it could be the wiring either; there's no way given what we know so far to eliminate one over the other.
