2015 WRX - Submitted a glitch on the multi function display to Subaru
Results 1 to 15 of 20
This is a discussion on 2015 WRX - Submitted a glitch on the multi function display to Subaru within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; I sent this email to SOA. Can anyone also experiencing this submit their issue? Hello, I just took delivery of ...
    Registered User Rainking's Avatar
    Dec 2013
    Binghamton, NY
    Hello,
    I just took delivery of my 2015 WRX (and would like to report a glitch in the multi function display in hopes it can be fixed via firmware update. The screen that shows three icons (MPG, ODO and ACCLR %) when customized, it resets to default value every 3 days or so. Also, I change it to display the summary after each drive and that also resets to the default value of "NO".
    Thank you
    It's not everything. I entered some birthdays and anniversary to see if those got erased; nope. Those are the only two things I've noticed so far. Got tired of setting it back to how I wanted it so I just left it to default setting. But then again, I haven't tweaked much of the other settings so I can't tell if that's also resetting. Might try changing the default values of the other settings to see if they stick.
    Registered User Raven Logics's Avatar
    Dec 2007
    Canada
    I haven't experienced any changes in my custom settings after 2 weeks, and my summary displays fine after each and every drive. Have you tried resetting the default values (I assume that's an option), or a battery pull?
    Dec 2013
    Binghamton, NY
    I'll try that, thanks. I know a few members on nasioc reported the same issue. It seems to only be the triple meters.
    Aug 2008
    Do you ever turn the screen off? It seemed to happen to me after turning the screen off.
    Dec 2007
    Canada
    Quote Originally Posted by Rainking View Post
    Any update Rainking?
    Dec 2013
    Binghamton, NY
    Still happening. All my customize setting in the triple meter and summary keeps resetting to default value. SOA have been responsive to my emails but don't expect any fix soon. Other people on NASIOC are experiencing the same issue. I believe most people don't realize it because they leave the default option on the triple menu so I urge everyone that has a 2015 to change it and if it resets, report it to SOA.
    Apr 2014
    Boston
    Same thing actually happened to my car this morning. I had originally set 3 custom displays when I took delivery last friday: current mpg, boost, and throttle %.
    This morning, all 3 were changed back to default, and the default screen was just on the boost gauge.
    Dec 2013
    Binghamton, NY
    Thanks Popotamus. Please report to SOA if you haven't already. Hoping for a firmware update.
    Apr 2014
    Boston
    Submitted.
    Also, submitted an issue with my bluetooth sync and my phone. But that's a separate topic...
    May 2014
    I have been seeing this issue about once a week. I was going to have the dealer pass it up but what email for SOA did you reach out to?
    I just registered for this thread. I picked my 2015 in Early April and this has been driving me nuts.
    Registered User 2Henchmen's Avatar
    May 2014
    Aspen, CO
    I just registered to weigh in on this as well. I'm having the same problem with my display, every few days it resets. Reached out to my dealer, but will also submit to SoA.
    Apr 2014
    Boston
    Knock on wood... But my display has remained the same for a couple of weeks now...
    Sent from my HTC One_M8 using Tapatalk
    Registered User jimnassium's Avatar
    Mar 2014
    Boise, ID
    Related but different ... are the number of characters in other's display truncated when viewing XM radio info (like 10 characters)? FM-HD shows full screen of characters ...
    2015 DGM WRX Limited
    Registered User TimbersWRX's Avatar
    Sep 2010
    Raleigh, NC
    I'm now having the same problem with the triple meter. I've had the car since May and it's been stable since then to about a week ago. Now it seems to reset every couple of days. Annoying. I'll be going in for an oil change soon, will report it then.
    Aug 2013
    try disconnecting both cables on the battery, and touching the positive and neg terminals together. this will hard reset the pcm. May help, or it may not. I know this fixes the power lift gate issues in the 15 outback and its a computer issue
