Replaced radiator still heating up.....IM LOOSING MY MIND!
Results 1 to 6 of 6
This is a discussion on Replaced radiator still heating up.....IM LOOSING MY MIND! within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Just replaced my radiator on my 04 wrx. It's still heating up and can't figure out why. Fans are working, ...
    Feb 2013
    PA
    Just replaced my radiator on my 04 wrx. It's still heating up and can't figure out why. Fans are working, put enough coolant in, and checked the pressure. Need some help
    Registered User Obeisance's Avatar
    Apr 2012
    not Ann Arbor
    Can you confirm that the system is well burped?
    Is there anything blocking airflow through the radiator (perhaps something in between the A/C condenser and radiator)?
    Have you checked on the state of the water pump and thermostat (are they still working properly)?
    Do you know if the water temperature gauge in the cabin is correct? (i.e. is there a gauge or thermometer problem)
    David - '05 WRX
    Feb 2013
    PA
    im going to try burping it again in an hour i just did it 10 mins ago had it on a hill, waited till the bubbles stopped and turned it off. I drove it up the hill and back and still heating up
    Registered User Ingo's Avatar
    Mar 2012
    Colorado Springs, CO
    Quote Originally Posted by Obeisance View Post
    Registered User CLMan's Avatar
    Feb 2014
    Hey man same thing happened to me when I picked up my 04 wrx it happened when the storm hit us, at first I topped off the cooliant to make it wasn't leaking and it was, it turned out that the CORE RADIATOR HOSE split, check your fluids
    Using Tapatalk
    Feb 2013
    PA
    Fixed
    It wasn't well burped and this was my first time changing my radiator, i do appreciate everyones replies!
