Massive clunking/bumping noise when I....
Results 1 to 12 of 12
This is a discussion on Massive clunking/bumping noise when I.... within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Ok so, when I try to launch with traction control off, I usually rev up to 4000-5000 rpm and dump ...
    Registered User LENSPEC's Avatar
    Dec 2013
    Long Island, New York
    Ok so, when I try to launch with traction control off, I usually rev up to 4000-5000 rpm and dump the clutch and the wheels start spinning but I hear 4 to 5 very loud clunks or bumps coming from under the car. Is this wheel hop? Or something else? What is causing this noise and what aftermarket parts can I purchase to eliminate this issue?
    I want to do some legally sanctioned 1/4 mile runs down at the track and would like to diagnose and eliminate this issue if possible before going there in the spring.
    Thanks,
    The rear diff and gearbox are mounted relatively flexibly. For the gearbox there are harder mounts; some where once homologated and so are still called "Group N." For the rear diff you can buy kits with bolts to secure it to the car.
    Registered User speedtown's Avatar
    Feb 2012
    VT
    probably mount problem. I know in my old speed6 my rear diff would make the most awful noise ever when taking off hard. I would say upgrade the different mounts and see if that helps, some of them are pretty flimsy. Maybe start with the tranny mount?
    Dec 2013
    Yeah I've been looking around. It seems that some of the more popular things are group-N mounts and kartboy engine pitch mount. But I'm not sure how a pitch mount affects wheel hop. I got a lot more research to do it seems
    Dec 2013
    And now after more research, I find many different types of mounts created by multiple different brands. This should be interesting....
    Dec 2013
    be sure to let me know what u end up doing
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    You want to check out turninconcepts.com
    Dec 2013
    oh damn....so many options that all appear to do the same thing.
    Is everything the same but with slightly different designs?
    Nov 2012
    If you are looking for rear diff look at the whiteline rear diff mount in cradle bushing. For the gearbox you can also look at whiteline positive shift bushing kit, and the group n transmission mount. Perrin also makes a rear diff lockdown kit.
    Dec 2013
    great thanks,
    has it been said that perrin rear bushings are better or worse than the whiteline ones, or vice/versa ?
    thanks
    Nov 2012
    Quote Originally Posted by LENSPEC View Post
    great thanks,
    thanks
    There is not much to them. Both companies make good ones. It is all dependent on where you want your money to go.
    Dec 2013
    True.
    In looking at both the whiteline and perrin rear diff insert kits, perrin seems much stronger.
