Driving with AC on? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on Driving with AC on? within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; That is what I also used to think, however, I found out that Arco is not top tier gas, which ...
    Aug 2013
    That is what I also used to think, however, I found out that Arco is not top tier gas, which means it does not contain the detergent requirements for optimal engine performance. Also, I feel quite a big difference between shell and Arco in the way the car drives. It's just not as smooth.
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Gas is NOT gas...It's actually gas. Gas is what it isn't.
    On a side not...When I monitor feedback knock I get slight knock with the AC/Defrost on. When I don't have them on I don't get it. That would tell me that AC/Defrost have an effect on how the car runs.
    I don't use AC/Defrost. I like to sweat.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    I definitely notice a diff with AC. Both MPG and Giddy up. A mechanic told me that the AC compressor will kick off in defrost mode on many cars as a dehumidifier.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
  6. #19
    Quote Originally Posted by scoobs1 View Post
    What are the detergent requirements for optimal engine performance?
  7. #20
    Aug 2013
    I am not sure what the recipe is. I do know that Chevron, Shell, 76 and Exxon/Mobil are all top tier gas and Arco is not
    On that list. You can read about it at toptiergas.com
  8. #21
    Registered User SDub's Avatar
    Feb 2013
    Unless I'm working out of my wrx in my button down and slacks, which is alot. I airways have my windows down because to compressor draws on the engine so much.
    I've stalled a couple times forgetting I have to feather alot more. Such a nub
    Sent from my Fone
  9. #22
    Consider that fuel is highly regulated, specifically as to content.
  10. #23
    Lando Calrissian DemonWRX's Avatar
    Jul 2011
    Cloud City, Bespin
    I think this is partially psychosymatic (the AC thing), and here is why. The next time you go for a drive, set your temp dial all the way to cold (the click below 65), the vent to the dash only setting (no foot well, no defrost) and the recirc to off (letting in air from outside) then drive around for a while. You will notice that the air coming out of your vents is far colder than the air from your windows being open, despite the air from the vents being heated by passing through the engine bay. Do you know why? Well, on the 3rd gens at least, the AC compressor cycles on and off even when you do not have the system set to run. You can also see this by using the same settings, starting the car, then popping the hood and watching the compressor while the car warms up. This means that in all likelyhood, with the AC off, you are still likely to shift (on occation) while the compressor is actively running....but as you know it is off, you think nothing of it (or don't even notice) and auto-correct with the throttle. However, with the AC on, you contiously know that it drains pwer from your engine and are acutely aware of the loss....even though it is only taking less than 3HP from your system.
    As for gasoline, I use only Sunoco or Shell, and Exxon in a pinch....cause Cheveron dosen't exist here in southwest PA.
    Stink-Eye Mob #39
    N.E.R.D. Operative #8
    2015 Dark Grey Metalic STI Limited - Stock (womp womp).....for now
    2011 Spark Silver WRX hatch - Returned to stock and traded in
  11. #24
    It's 40 outside right now. The A/C is staying on.
    I buy gas based solely on price. In the absence of data the rest is all marketing. I like money more than marketing.
