Too much vibration?
Results 1 to 15 of 17
This is a discussion on Too much vibration? within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; OK this may be a dumb noob question, but on a longish drive in NE via I-80 recently I noticed ...
    Registered User Doctor Jeff's Avatar
    Jul 2013
    Omaha, NE
    Too much vibration?
    OK this may be a dumb noob question, but on a longish drive in NE via I-80 recently I noticed a fair amount of vibration both on the steering wheel and from the body. Now normally I would attribute this to our horrendous roads, but this stretch of asphalt was laid this spring. It is a 2012 WRX Premium with 17K miles. No problems with braking or turning. Fairly new Fuzion tires with most of tread. It seems more noticeable at 75-80 mph than less.
    By comparison, with my previous ride, BMW Z4, I felt every rock on the road, so vibration was not really noticeable in the context of a really rough ride. On my fiancee's Chevy Avalanche there's similar vibration, but then that's a truck.
    My guess is it's coming from the tires and road plus minus some engine noise. I previously had a Honda CRV that had horrible noise and vibration that went away when I got new tires (though previous Goodyear Triple Treads were only about a year old--bad experience with these tires). And I know Fuzions are not top-quality tires.
    Any thoughts? Is slight vibration par for the course with this car at higher speeds?
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    1. Check air pressure.
    2. Check alignment.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    hmmm maybe you need to balance your tires
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
    Registered User Soobvirgin's Avatar
    May 2012
    San Diego
    When did you last have the wheels balanced?
    Jul 2013
    Omaha, NE
    I just purchased the car used from CarMax. I assume air pressure is OK, haven't checked it yet. I don't know when it was last balanced. I can take it in to have them look at it next week though (30-day CarMax warranty).
    Nov 2012
    Lansdale, PA
    Do what Zax told you to do. You could also do a road force balance, if you can get it for free under the warranty.
    Also, check the inner part of tires....are they really worn? If so, then its an alignment issue.
    ¯\_(ツ)_/¯
    May 2012
    San Diego
    Quote Originally Posted by Doctor Jeff View Post
    Then air pressure and balancing is where I'd start. Then check alignment and bearings. Having said that, I've never heard of Fuzion tires. Could just be caused by cheap, crappy tires.
    Jul 2013
    Omaha, NE
    Fuzion is I believe a subsidiary of Bridgestone, maybe their discount brand? They are made in the USA. These are UHP's, all-season tires. While in general you get what you pay for with tires, I have had some bad experiences with expensive, highly rated tires. I do not see any appreciable wear or uneven wear. My guess is the previous owner slapped a new set of tires on the car before he traded it in.
    May 2012
    San Diego
    So are Big Macs. Doesn't mean they won't kill you.
    Possibly. I'd have everything checked out first. If your problem still isn't solved, try a set of better quality tires. If Fuzion tires provided excellent all-around performance on the WRX, Subaru's OEM tires wouldn't be something that cost two or three times as much.
    Just a thought. Hopefully it's as simple as rebalancing them.
    Registered User Kwrxp's Avatar
    Aug 2012
    Spring Grove, PA
    Also, you should still have Subaru's warranty too. Just so you are aware that after Carmax's 30 days are up, you still have warranty. Also, check the pressure. I had a wobble around 75-80 and turned out my left front was a bit lower than the others.
    '11 WRX DGM
    Palmyra, NJ
    I can't read the title of this thread on the main page without laughing.
    /immaturity
    zax
    zax is offline
    Nov 2008
    Turn the knob down on the vibrator /immaturity
    Facebook me here
    Jul 2013
    Omaha, NE
    I logged another 200 highway miles in the WRX over the weekend. I'm convinced it's a combination of factors: engine hum, Subie suspension, sympathetic vibrations, and tires. It's really pretty subtle, on a par with my fiancée's Avalanche, but I guess I was expecting something much cushier after my Z4's unforgiving ride.
    To put it in perspective, it is a a LOT smoother than the Z4 and makes me not wince every time I hit a crack or pothole.
    I agree the tires could be playing a role - I replaced some bad tires on my CRV and the difference in ride and road noise was night and day. These tires have a lot of tread and LOOK GREAT, so I will probably keep them on til winter then consider some real winter tires.
    Jul 2013
    Omaha, NE
    Btw I do miss the 6th gear from the BMW. A little over 2000 rpm with the Beemer in 6th gear vs 3000 in the WRX in 5th gear does make a difference.
    Jul 2013
    I bought my current miata from Carmax and it does the same thing.. I brought it back to tell them that it shakes from like 65-70 and they said it's because it's a convertible.. I drove other same gen miatas and while they do shake, mine is much more noticeable. I would just demand that they check everything for you since you have that warranty
