Storing 2007 WRX for 6 months
Results 1 to 15 of 23
This is a discussion on Storing 2007 WRX for 6 months within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Hello everyone, I have been out of the country for 6 months and my 2007 Subaru WRX hasn't been started ...
    Mar 2013
    A, A
    Hello everyone,
    I have been out of the country for 6 months and my 2007 Subaru WRX hasn't been started since I've been gone. What are some recommendations on how I should get it back going to what it was when I left? I am expecting a dead battery and for it to run a little rough because of the stale gas that was left in the tank. Should I get an oil change right away? Should the tires be inspected? Anything with the brakes?
    Any and all recommendations are welcomed.
    Thanks,
    Mike
    Jan 2012
    Philly Area
    6 months...I probably wouldn't even want to try and run it with the gas that's in it if there's a significant amount. If it were me I would get that gas outta there and put fresh fuel in before starting the car.
    - Will
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    I would definitely get an oil change. You might luck out with the battery and find that it is ok (but may need a jump start). Not sure on the gas, but if it were me I probably would have parked it on low gas and then bring fresh gas in a can when I go to get it! Good luck and I am sure you will get more helpful responses here!
    Mar 2013
    A, A
    Thanks. When I initially parked the car I left gas in it because someone was going to start it for me every two weeks. Then they let the battery die and it won't start now.
    Mar 2013
    A, A
    How would you get the gas out?
    Nov 2012
    Quote Originally Posted by Thekep1014 View Post
    Another thing to be aware of is that depending on the environment you may have some rust on your rotors/brake pads, so the first time you go to stop your car it might not be as responsive until you brake hard a few times to wear that off. Don't want to go flying through an intersection!
    Nov 2012
    you can syphon it. Common way that people steal gas from parked cars...Just don't swallow any!
    Mar 2013
    A, A
    I think it's a little less than a half tank. Would you recommend mixing premium gas with it to make it not as bad?
    Nov 2012
    Honestly, you would probably be fine doing that, but if it were me I would probably try to syphon as much out of there as I could. Did you happen to add any gasoline stabilizer to it before you stored it or was it just straight gas?
    Mar 2013
    A, A
    It was just straight gas. Should I add one of those STP octane boosters or fuel injector cleaners?
    Nov 2012
    It's really just that the gas probably deteriorated significantly over that time. The octane booster won't fix that (or really do much of anything except cost you money). I would try and syphon out the gas. It is really quite easy to do. The fuel injector cleaner probably wouldn't hurt.
    Mar 2013
    A, A
    Ok. Thanks for your advice.
    Nov 2012
    Yep no prob. I am sure some more people will chime in too! Good luck!
    Jan 2012
    Philly Area
    I believe there are actually drain plugs somewhere on the tank.
    Edit. Filthy Lies!
    Looks like 07+ doesn't have drain plugs. Here's an excerpt from someone on nasioc describing what they did.
    Anyway I drained the fuel tank by removing the supply fuel line from the fuel pump and attaching a hose of my own to a jug and then primed the pump over and over till I had pumped out a few gallons. I supposed I could have tricked the relay into staying on, but I'm not sure where it's located.
    You could try siphoning it, but aren't modern cars set up to make that difficult/impossible?
    - Will
    Nov 2012
    I think you are right actually. I heard that a few years back when I was paronoid that people were going to be stealing my gas when prices skyrocketed!
