I Need Opinions - Page 2
View Poll Results: Which Engine Would You Get?
Voters
19. You may not vote on this poll
  • ej205
    4 21.05%
  • ej207
    5 26.32%
  • ej257
    14 73.68%
  • Other Engine (including boobs)
    6 31.58%
Multiple Choice Poll.
Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
This is a discussion on I Need Opinions within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; Originally Posted by zax If you can find an EJ207 case, I'd go with that... the EJ207 has the semi-closed ...
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    If you can find an EJ207 case, I'd go with that... the EJ207 has the semi-closed deck design (not that this would truly matter at power levels < 500whp) and better oil journals/thrust bearing design.
    The EJ25 block (both 255 and 257) also have semi closed deck blocks. And apparently the bearings aren't an issue as crawford uses OEM bearings in some models of their upgraded engines. When I build my engine... I will use OEM STi bearings, and OEM STi rings.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Moderator T0rque's Avatar
    Dec 2004
    Medford, Oregon
    Yes
    Lead Wrench @ WTF Tuning, LLC
    Dec 2004
    Medford, Oregon
    both have forged rods, and hypercast pistons (hypereutectic)
    Wasnt positive about the rods. I didnt think the pistons were different.
  6. #19
    Jan 2005
    Eh, whaaaaa?
    I vote hybrid build.
    And boobies.
    Cody
  7. #20
    If you go the hybrid route, you should have the heads worked on. EQTuning offers this service:
    Exciting New Head Option for EJ205/EJ257 Hybrid Builds! - Subaru Impreza WRX STI Forums: IWSTI.com
    Resident Tuner @ WTF Tuning
  8. #21
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    I didn't say that they didn't have semi-closed decks. I was talking specifically about the 2.1L stroker build, and that requires a 2.0L block. I was only referring to the EJ207 block over the EJ205 block
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
  9. #22
    ClubWRX.net Vendor rexxx0486's Avatar
    Jan 2007
    North NJ
    just for ****s and giggles I checked my parts dept. and we sell the ej205 shortblock new for 1875. btw just curious, what kind of hp will the automatic support?
  10. #23
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    What I'd do, if I were to go with the auto... Now this also depends on finding one intact but I'd try to find a wrecked 08 2.5gt (ej255 w td04 turbo coupled to auto trans) and pull the 2.5l engine/trans/management/harnesses out of that and drop it into your project. It would be a bit of work but a really solid daily and lots of potential to build later on.
    My reasoning is simple. Auto's need torque, 2.5 w td04 turbo makes good torque and the turbo spools right effin now. Quick spool and a little more displacement to begin with will take the dull laggy feeling out of the auto.
    hard part: finding a wrecked 2.5gt.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
  11. #24
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Honestly it doesn't matter EJ255,EJ257,EJ205, hybrid (EJ20x heads on an EJ25x short block) all are great options, all you will be happy with, some will cost more than others. If you do go the EJ25x route the increase in torque will definitely necessitate a tranny rebuild.
    Lets take a look:
    EJ205:
    Pros
    *Direct replacement
    *stock ecu will work no need for a tune.
    *Might get away without a tranny rebuild for a while
    *no need to immediately upgrade fuel system
    *great daily driveability, proven reliability
    *potentially cheapest
    *can use some existing engine parts
    * stock wiring harness will work
    cons
    *Not as strong a platform to build to the moon
    *does not make as much torque as the EJ25x
    Hybrid:
    Pros
    * Can build a ton of power
    * can use the stock EJ205 ecu to tune
    * more torque out of the box
    cons
    * requires immediate tuning
    * requires immediate fuel upgrades
    * requires a set of ej20x heads and machining
    * tgv deletes good idea
    * sacrificed longevity and reliability
    * has to be built can't be bought off the shelf
    * not cheap
    EJ255
    pros
    * can be bought off the shelf
    * makes lots of torque
    * reliability and longevity in stock form
    * good Daily driving
    cons
    * not a bolt in swap
    * need new harness
    * need new ecu
    * need new fuel system
    * build that tranny
    * might need new tranny harness
    * drive by wire, need to change out gas pedal, TB, etc
    * new engine harness needed
    EJ257
    pros
    * make a ton of power
    cons
    * need new harness
    * need new ecu
    * build that tranny
    * never came with an AT hooked to it factory
    Now, if you are just going to use it as a DD and not looking for power over 300whp, and want to stick with the AT, I'd stick with the EJ205. It is the easiest to do.
    I'd buy a td05h-16G with EWG, a bigger top mount, EBCS, Walboro, injectors, up pipe, down pipe, grimmspeed ported/coated headers, rebuild the tranny, higher stall converter, tactrix cable, new axles, new driveline.
    For engine availability, don't be scared of calling dealers and having a stock one shipped. I mean your original engine went 260,000 miles. You can also call tuners and see what they have for stock.
    Not a fan of EQ. They are semi local and don't have a great rep.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  12. #25
    Palmyra, NJ
    I thought the 4EAT was a very strong transmission that relatively ever broke? Or is the issue here that its just already old with a lot of miles through it? The torque increase from an EJ25x wouldn't be THAT much in the grand scheme of things unless going on through Stage 2 and further...
    And just a generalized question...if you did put in a V7 or similar JDM STI BLOCK only, but kept the stock heads and just machined them for optimum fit...does the ECU/harness still need to get swapped as well?
  13. #26
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by 06wrx4me View Post
    Is there a consensus that the hybrid motors won't last? We do seem to have a number of folks around that have blown there's up...but we're talking STI_KLR and Justin, here, so I'm thinking that they'd break whatever you put in there.
    I was hoping that mine would last another 2 years for me, anyway...long enough to offload it onto some poor, unsuspecting high school kid.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  14. #27
    Oct 2009
    longevity is in the tune.. conservatively tuned any engine will last as long as its built correctly.
    SWP 2013 FRS
    SUCH IS MANGO!
  15. #28
    Palmyra, NJ
    RoffleClamfed... +4 Drews for you sir.
  16. #29
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    How long have you had the hybrid Ray? I'm considering this route at some point in the future, but considering the investment could be put toward a down payment on a new STI, the hybrid would have to be worth it.
    2007 Outback 3.0R wagon
  17. #30
    Palmyra, NJ
    Quote Originally Posted by Rambo View Post
    I think Shawn hit it on the head with the tune...as long as it's built properly, and your heads are machined and worked properly to fit the block, the tune has to be absolutely perfect, and more or less on the conservative side.
