Results 1 to 7 of 7
This is a discussion on Sway Bars within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; I'm getting a 2012 Subaru WRX 5-door Premium and I wanted to know what size of sway bars I need. ...
    Feb 2012
    Orem, Utah
    Sway Bars
    22? 24?
    Fixed? Adjustable?
    Should I get the rear sway bar with a mount and support braces or not?
    Should I get the same size for the front and back?
    I'm thinking about getting Whiteline, is that a good idea?
    Registered User SRTSamb's Avatar
    Mar 2011
    Virginia
    Most people go 24/22, I did. It's hard to say objectively what you "should" do.
    There is a FAQ laying around here somewhere (look in RageWRX sig) it will give you a lot of Great info. And probably help you understand better why you should upgrade your sways, which to me is more important. (the why)
    2011 OBP WRX::Invidia Catless DP::Cobb CAI::TP 93 STG2::KB STS::Perrin Sways::
    Adjustable sways allow you to fine-tune the system without buying new parts; I would absolutely buy adjustable bars.
    24 F / 22 R is a popular setup. Go to an Auto-X test/tune and push your car to the limit in a safe, controlled environment. Make adjustments as necessary.
    Whiteline is one of the leaders in suspension parts for a reason.
    Mar 2011
    Virginia
    found them in the Suspension section of this forum
    How to: Suspension Tuning
    Swaybar & Endlink FAQ
    Negative pantsy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    24F/22R is the most popular setup.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
    Feb 2012
    Orem, Utah
    Should I get the holy shift kit wide or narrow for the bushings?
    The Fruit mangostick's Avatar
    Oct 2009
    the ghettooooo
    your car will use the same shifter bushings as the 09-11 cars. I believe it was the wide kit.. cant remember as I purchased mine a very very long time ago.
    sway bar wise I'm running 25mm front and 20mm rear... both adjustable. Front is Perrin and rear is whiteline. Either way you should get some seat time in the car before you start changing things. Shifter you can change right away, but suspension wise I'd hold off until you realize where changes actually need to be made. Also, you'll better see the difference after the change if you've driven for a while on the factory equipment.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
