Can you fill a Nitrous Oxide tank with C02 ????? - Page 2
Results 16 to 30 of 41
This is a discussion on Can you fill a Nitrous Oxide tank with C02 ????? within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; forget CO2 its bad for the environment, just get some Halon instead. All the places I know will not fill ...
    Registered User Scottyb0119's Avatar
    Feb 2011
    Cleveland Ohio
    forget CO2 its bad for the environment, just get some Halon instead. All the places I know will not fill a bottle with the wrong gas its labled for, also the hydro date better be good too.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    That's true. It's against federal law to fill a bottle that's labeled incorrectly.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Registered User Civic_jdm16's Avatar
    Sep 2009
    Clearwater, FL
    Since we are on the subject I have another question that has to do with this topic..... Ok so one of my friends & I guess some other subaru owners are taking off the antifreeze line that runs into the throttle body. They say it keeps the throttle body cooler.
    My question is would it be possible to run C02 through it before it reaches the intercool sprayer?
    Im thinking that could could lead to something bad... If you would happend to spray it wail at wide open throttle & the throttle body would freeze you could be in some trouble......
    Has anybody ever tried this?
    "SCHIRRA~#16" HOLY *****'N A$$ CRACKERS!!!!!
  6. #19
    Feb 2011
    Cleveland Ohio
    Quote Originally Posted by Civic_jdm16 View Post
    That first thought that pops into your head is usualy the right one, yes its bad.
  7. #20
    Nov 2006
    Denver Metro Area
    It's a pretty common modification to do. It's there so the butterfly (the throttle valve) wont freeze shut. Since you live in texas, you're fine doing the mod. Here's the right way to do it: DIY Throttle Body Coolant Bypass Mod - Rexnet Subaru Forums
    I absolutely wouldn't cool the throttle body with CO2
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  8. #21
    Registered User efmd3's Avatar
    Jun 2006
    the ham
    wise words. not to mention the EXTREME pressure it would see from that causing some sort of chaos...
  9. #22
    Apr 2007
    8000' up in Colorado
    N20 bottles look better, & from what I see you can only get them in up to a 10 pound bottle. Maybe I want something Polished lol
    That's absolutely untrue. You can get C02 bottles much larger than 10 pounds. After all, a standard C02 fire extinguisher is 20 lbs.
    Because of the pressures involved this is not a question to ask here. This is a question to ask the tank manufacturer. The answer should involve an initial question from them back to you, about what fittings are on the tank right now, what gasses have been in the tank, and what pressures you are interested in maintaining.
    If you don't ask them, and they in turn don't ask you, don't do it IMO.
    +1 get the right tank for the right gas.
    Quote Originally Posted by hagen505 View Post
    The valve on the CO2 is different from the N20, so the gas supplier would not be able to fill it. You should be able to exchange the tanks with the retailer though. I usually get stuff like that through a local place, called Airgas. If you go to Airgas.com, you can find a place probably near you, call them up and see what they can do.
    +1 as he and many other people have said, nobody legally can fill the tank if it's labeled for another gas.
    Definitely not. I'd use hydrogen for sure.
    Scott
  10. #23
    Registered User hagen505's Avatar
    Dec 2010
    Illinois
    Quoted from the Cryo2 FAQ.
    Can I use my old nitrous bottle with this system?
    A nitrous bottle is very similar but the nitrous valve is different from the CryO2 Tank valve and the filling station will not be able to fill it with CO2.
    http://www.1fastcar.com/sa/p/CryO2_1...0_lb_Tank).htm
  11. #24
    Jul 2004
    Seattle, WA
    CryO2 10 lb. Installation Kit (No Tank)
    Best answer ^
  12. #25
    Sep 2009
    Clearwater, FL
    Call "Harry"
    I called Zex's tech support to ask them this question.... 1-888-817-1008.
    Both gases can use the same tank design.
    The whole thing about the label isn't a huge factor. (most) gas companys have pre printed labels in stock...
    I realy don't think the D.O.T is going to pull me over take out the bottle and test the gas to see if it is the same as the label...
    If it it was a hazmat issue I could understand why this would be such a big factor. like if you wanted to put propane in a C02 bottle.
    Also I maybe should have said this before, but I didn't I weld for a living & Oxygen, C02, Argon, Helium, & any type of non flamable gases all use the same valve.
    Most even use the same type of regulator....
    Ok the big question is this valves issue...
    C02 tanks & Nitrous Oxide tanks both use various types of valves, so the only issue would be is finding a C02 filling station that would accept a Nitrous Oxide tank valve..
    The type of Valve would not realy matter as far as flow of gas, freezing up, ect... The only thing that would matter is having a valve with a dip tube to suck the gas from the bottom of the tank to prevent freezing wich most nos/c02 tanks already have.
    Blah I didn't want this to go this far, but just to give u an idea of how little this valve factor matters...
  13. #26
    Palmyra, NJ
    Oh yeah, that system comes stock on the all new Subaru Hindenburg, right?
  14. #27
    Jun 2006
    the ham
    it also coats your entire engine bay with thermite in case of an emergency, lol
  15. #28
    Jun 2006
    the ham
  16. #29
    Apr 2007
    No it's an option.
    Quote Originally Posted by efmd3 View Post
    Another wrong answer. It coats it with pentaerythritol tetranitrate.
    Come on people doesn't anybody here know their stuff?
    Scott
  17. #30
    Nov 2006
    Denver Metro Area
    it's "Octanitrocubane" not pentaerythritol tetranitrate
    Kevin
    Moderator
    WRX Gas Mileage FAQ
