MY 03 WRX wagon build - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 58
This is a discussion on MY 03 WRX wagon build within the Everyday Impreza Talk forums, part of the Community - Meet other Enthusiasts category; im about to start pulling the engine so i can finish painting, shaving tucking the bay, new clutch and flywheel, ...
  1. #31
    NJO
    NJO is offline
    Registered User NJO's Avatar
    Oct 2007
    SL,UT
    im about to start pulling the engine so i can finish painting, shaving tucking the bay, new clutch and flywheel, new timing belt and timing belt guide, and painting the engine itself... this is going to be hard with 1 arm.
    EX BUGEYE MAFIA #193
    1996 Legacy Outback
    Ej20 swap/ with ALL supporting parts
    intake/turbo inlet/vf39/big tmic/headers/uppipe/downpipe/straight pipe/walbro fp/modded stock injectors/ and too much more
  3. #32
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    What is "shave tucking"
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  4. #33
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    my bad, i ment shaving AND tucking...
    1996 Legacy Outback
  6. #34
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    re making and re routing an enigne wiring harness is fun not.
    i will post [ictures as soon as its complete, then the next step is to pull the engine and paint!
    1996 Legacy Outback
  7. #35
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by NJO View Post
    What is this...?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  8. #36
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    What is this...?
    shaving all the bumps, screws, brackets etc out of the engine bay and then tucking all the wires out of the way so you barely see them and everythign looks smooth and nice with no wires or battery or anyhting like that...
    great example
    Attachment 89384
    1996 Legacy Outback
  9. #37
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    some shots of the engine bay, alot of the wires are tucked and hidden more with the new wiring hrness and alot of the brackets are gone and the throttle cables have been re-routed and i did the upper coolant tank delete and a/c delete and put the fuse box and light ballasts in the fender and tucked away the boost controller and all that stuff. i still need to extend and hide the wiring harness plugs in the driver side. but it should look good with everything painted once its done!
    Attachment 89394
    Attachment 89396
    Attachment 89395
    Attachment 89393
    1996 Legacy Outback
  10. #38
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    before shot... i never took pictures of the engine so this is about all ive got to compare it to... but as you can tell it looks alot different.
    Attachment 89397
    1996 Legacy Outback
  11. #39
    Nov 2006
    Denver Metro Area
    Awesome... You DEFINITELY need to do some rust removal!
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  12. #40
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    yeah when i pull the engine its all getting grinded down and sanded and alot of prep work then painted. and it will start to look a lot more together when i start getting hoses and everything the same colors.
    1996 Legacy Outback
  13. #41
    Nov 2006
    Denver Metro Area
    awesome cool project
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  14. #42
    Apr 2010
    your car is going to be a mad man
  15. #43
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    Quote Originally Posted by Cmaj7th View Post
    i sure hope so!
    1996 Legacy Outback
  16. #44
    NJO
    NJO is offline
    Oct 2007
    SL,UT
    FINALY! some picture updates, ive been busy lately trying to get back to work in a new job but heres some new pictures, i have decide to wrap it instead of paint it for the ease of body part replacement so ill start wrapping it this week!(same color)
    hidden engine harness
    Attachment 89670
    window switch relocation for my door panel delete
    Attachment 89674
    coolant tank delete
    Attachment 89669
    SEATS IN! just the stock ones, didnt want to get the sparcos dirt while im still working on it
    Attachment 89671
    the pink the engine bay is going to be
    Attachment 89667
    more coolant tank delete
    Attachment 89668
    i will be getting some new wheels, but what do you guys think about the green?
    Attachment 89672
    a shot through the hatch
    Attachment 89673
    1996 Legacy Outback
  17. #45
    Nov 2006
    Denver Metro Area
    you should probably have some sort of notice on the car window, etc. about where your battery is located, and where the main power wire goes. It'd be a shame if you got in a crash and the firefighter that's trying to cut you out of your vehicle hits the power wire and gets severely injured just because you wanted the battery in the back...
    Just sayin...
    Kevin
    Moderator
    WRX Gas Mileage FAQ
