There is a TSB out for the 09 WRX which states there may be a clicking noise from the bottom of the A-pillar...not to sure what you guys are hearing and how its best described but I have a guy feeling this TSB would be something to check into..ah here we are..pulled it off Subarunet for you guys...
NUMBER: 12-113-09
DATE: 08/03/09
APPLICABILITY: 2008~2009MY Impreza Sedan / Wagon / STI
SUBJECT: Noise from “A” Pillar
SERVICE BULLETIN
ATTENTION:
GENERAL MANAGER ❏
PARTS MANAGER ❏
CLAIMS PERSONNEL ❏
SERVICE MANAGER ❏
IMPORTANT - All
Service Personnel
Should Read and
Initial in the boxes
provided, right.
Introduction
If you encounter a customer complaint of a sharp click type noise coming from the bottom of
the “A” pillar trim, it may be due to free play caused by installation variance and/or temperature
difference. The noise is normally heard while driving over bumpy or rough road surfaces
when temperatures are 50°F or lower. To eliminate the noise refer to the repair procedure
listed below.
Countermeasure in Production
The length of the non-woven tape was increased to 50mm in July, 2008 starting with the
following VINs:
Model VIN
Sedan 9G500668
Wagon 9H800721
STI 9L800723
Part Information
Part Description Part Number Remarks
Non-Woven Tape SOA963W110 1 - 8 x 11 Sheet, thickness
0.43mm (Needs to be cut to size)
Repair Procedure/Information
• Remove “A” pillar trim (refer to the applicable service manual).
• Cut the non-woven tape to size, long enough to cover the front and back of the tab
as illustrated.
Note: Make sure the “A” pillar trim is room temperature and clean and dry before installing
tape.
CAUTION: VEHICLE SERVICING PERFORMED BY UNTRAINED PERSONS
COULD RESULT IN SERIOUS INJURY TO THOSE PERSONS OR TO OTHERS.
Subaru Service Bulletins are intended for use by professional technicians ONLY. They
are written to inform those technicians of conditions that may occur in some vehicles, or
to provide information that could assist in the proper servicing of the vehicle. Properly
trained technicians have the equipment, tools, safety instructions, and know-how to
do the job correctly and safely. If a condition is described, DO NOT assume that this
Service Bulletin applies to your vehicle, or that your vehicle will have that condition.
Subaru of America, Inc. is “ISO
14001 Compliant”
The international standard for excellence
in Environmental Management Systems.
Please recycle or dispose of automotive
products in a manner that is friendly to our
environment and in accordance with all
local, state and federal laws and regulations.
continued...
Bulletin Number: 12-113-09; Date: 08/03/09 Page
• Peel off backing of tape and apply to “A” pillar.
Right Side
Right Side (reverse side)
• Install “A” pillar trim in reverse order of removal.
Warranty/Claim Information
For vehicles within the Basic New Car Limited Warranty period, this repair can be claimed
using:
Labor Description Operation # Fail Code Labor Time
“A” Pillar Modification A913-171 YCJ-48 0.2
Parts: Use part # SOA635079 for non-woven tape. The part # is non-orderable and used for
claim purposes only.
